#1 | |
Quick Disconnects
I have a set of the JKS quicker disconnects installed on my Rubi and when I tried to disconnect the passenger side i couldn't even budge it. The drivers side comes off no problem, just remove the pin and its that easy. Also when I try to put the drivers side out of the way on the holding pin it doesnt fit properly. There is no way the holes line up to put the pin back in to secure it out of the way or are they just supposed to hang there. The disconnect is about an inch or 2 too long compared to where the storage pin is. The hole on the disconnect(sorry not sure of the name) does not fit over or reach the storage pin. I had my lift professionally installed. Am i just being stupid here? Any help would be greatly appreciated.
#2 |
Anyone have any thoughts?
#3 |
hum pics would help, try putting on one side, then driving that side thats ON onto a curb or little rock and see if you can fit in on then, wd-40 helps them move easier, or if it doesnt line up at all cut new holes in them
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada |
#4 |
I had the same issue with my JKS disco's as you did.
1) Remove the "easy side" 2) Remove the side that is stuck and use the threaded adjuster to lengthen the quick disconect. It should reinstall much easier for you. 3) Re-install "easy side" disco and then adjust "hard side" disco to make sure that th disco fits properly. Does this make sense?
Red 93 YJ 33" X-Terrains/Super 35 kit/Detroit Locker/4.88 gears RE 4.5" ED lift/SYE & Tom Woods shaft/Tera 4low Warn bumpers F & R/Warn gas tank skid 4 point harnesses/Poison Spyder sliders Warrior Corner Guards/JKS Quick Disco's & telescoping front track bar/M.O.R.E. Rear traction bar/PSC ram steering Borla header/Turbo City intake/Flowmaster muffler/new cat all propelled by a [B]MONSTER [/B] 2.5l I4 |
#5 |
Do it right or not at all
![]() Join Date: Jan 2003
Were they installed while the Jeep was sitting on a perfectly flat surface? It almost sounds like they weren't.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#6 |
If I could only figure out how to post pics i coud show it to you guys. Maybe if I could e-mail them to some of you I would appreciate it. let me know please
#7 |
You can't put one side on the storage pin while the other side is connected. You need to disconnect both sides, then store them up on the storage pins.
You can adjust the length of them when you go to reconnect, if necessary. Make sure your Jeep is on level ground & it will help with connecting and disconnecting them.
'01 TJ with mods... :) [COLOR=white][B]White[/B][/COLOR] Jeep Club Member #22 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
