Question about changing my wheels
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
I am planning on ordering some of the 15x8 Cragar Soft 8 wheels. I currently run a 15x10 wheel and a 31x10.5 tire. With a 2" RE BB and the 15x8 Cragars and 31x10.5 tires...am I going to be good to go? Will I need to order anything else to prevent rubbing? Thanks in advance.
#2 |
Jeep
Wow... 10" wheel and 10.5" tire.. I'm impressed
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#3 |
Make sure the backspacing is 4" or so. Stock is 5.5" and you need to make sure the tire stays moved out a bit.
jim
03 Sport |
#4 |
You'll be fine. That's the exact set up I'm running. I've got the soft 8s with 4.0" of backspacing with 31 X 10.50 MTs and the only rubbing I get is on the fender flare at full flex and some wheel turn. When I furst got my tires I had the stock rims and they rubbed the lower control arms at full turn. It wasn't a big deal, just back off a little bit and the problem was solved but it was annoying.
You'll like the set up.
77 CJ 7 - 304, TH400, Dana 300, Locked Scout 44s F/R, 4140 Chromoly Shafts, Bead locked TSL Q78s |
#5 | |
The closer you get to 5" BS, the better off you'll be. You need to take into consideration how the new wheel and tire will mount on the spare tire carrier too. 5" BS would be perfect. But I think 4.75" is as close as you'll find. |
#6 |
He'd be fine with a 4.0" back-spacing. The tire will stick out farther than a stock rim but that's not necessarily a bad thing as it will broaden his stance and provide more stability.
However, there may need to be some adjustment to the rear rubber tire bumpers on the tailgate. But there are various ways around that. Such as picking up a spare set of the rubber spacer, cutting them down to a 1" height, gettin longer screws, and stacking his stock rubber spacers with the moddified ones. Going from a stock 9.5" wide tire and 5.5" back spacing to a 10.5" wide tire with 4.0" of back spacing would necessitate a 1" spacer being added tot he rubber tailgate bumpers. Plus, by running the 4.0" backspacing he can upgrade to a 32x11.50 tire to run with the 2" BB if he wants and still have plenty clearance. And he'd just need to add 1/2" spacer (cut rubber tire bumpers) to the tailgate.
- Jay |
#7 | |
#8 |
That is the exact set up I have and I have no rubbing whatsoever. The spare fits fine also.. no adjustments were necessary.
#9 |
Do it right or not at all
![]() Join Date: Jan 2003
A 15x10 wheel is way too wide for a 31x10.50 tire. The tire's 10.5" width is at its widest point half-way up the sidewall, not its natural bead width. That tire would have a heck of a time remaining securely seated on a 10" wide wheel if it were not fully aired up. For that size tire, I'd run nothing wider than a 15x8. 5" of backspacing is fine for that width tire.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
