Pro Comp X vs MT/Rs - Page 2 - JeepForum.com
post #16 of 19 Old 04-26-2004, 06:38 PM
yj_magnus
yj_magnus's Avatar
I just skimmed all the other posts so I hope this didn't get covered. True beadlock rims aren't street legal in a lot of states, you'll want to check on that. Also, if you're not airing down to 8psi to crawl on some rocks, I wouldn't think you'd need beadlocks.
As for the rubber, I've run both. The Xterrains weren't bad, they will shake the hell out of you under 10mph and then they settle down. They're pretty quiet and seemed to hold up okay for the first 10k miles (thats when I got rid of that jeep). My only complaint was that they seemed to hydroplane more easily than some. I never noticed if they were smaller in diameter than other 33"s.
The MT/Rs are sweet (and way better looking IMO ). I'm just past the 10k point and I'm just starting to see some wear, so I'm betting on 40k. They handle great, and don't really make that much noise either. So far, call me happy.
See, its like my grandaddy use to alway say "When hell is full, the dead will walk the earth"
yj_magnus is offline
post #17 of 19 Old 04-27-2004, 07:38 AM Thread Starter
Sues TJ
Sues TJ's Avatar
Thanks! I think I've desided to go with the MT/Rs. I've called around to a few places. 4WP has a package deal but I got a cheaper price for black steel rims and the tires from America's Tire company. ATC has dozens of locations that will balance the tires and rotate them for free. So looks like I'm getting everything there. Besides, some tallent at the larger 4wheel shops seems to be lacking these days.
Sues TJ is offline
post #18 of 19 Old 04-27-2004, 08:28 AM
pdw
pdw's Avatar
Originally Posted by Sues TJ
Thanks! Besides, some talent at the larger 4wheel shops seems to be lacking these days.
And here I thought that I was the only one to think that was the case!
Red 93 YJ
33" X-Terrains/Super 35 kit/Detroit Locker/4.88 gears
RE 4.5" ED lift/SYE & Tom Woods shaft/Tera 4low
Warn bumpers F & R/Warn gas tank skid
4 point harnesses/Poison Spyder sliders
Warrior Corner Guards/JKS Quick Disco's & telescoping front track bar/M.O.R.E. Rear traction bar/PSC ram steering
Borla header/Turbo City intake/Flowmaster muffler/new cat
all propelled by a MONSTER 2.5l I4
pdw is offline
post #19 of 19 Old 04-27-2004, 08:43 AM
GrimJeeper91
GrimJeeper91's Avatar
Don't forget about the free flat repair as well. Since there are a lot more America's/Discount Tire Centers around the county this is of more value than free flat repairs by 4WP. If you want added protection by the Certificate's. This gives you free tire replacement if you bust a tire and it can't be repaired. I think I got this for an extra $20 bucks a tire. There is a limit, however. If you are one of those guys that busts two tires every time you go out they will eventually cut you off. This happened to a friend of mine. He would tear out the sidewall of two tires almost every trip. Discount Tires finally said enough and won't replace any more tires free of charge. Personally I don't think this policy is unreasonable. If you're not paying attention to tire placement and constantly ripping out sidewalls then your a lousy driver in my book. I'm very aware of tire placement and will gladly adjust my line if I feel like I might damage a tire. As a result, aside from popping a bead, I have never had a flat (knock on wood).
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
Pro Comp M/T or BFG M/T km1? Smallz Tires & Wheels 7 03-12-2009 04:09 AM
32's vs 31's? (32s= AT/KO vs Pro Comp) (31's= **** Cepek FC IIs vs BFG vs Pro Comp)?? TJoshX Tires & Wheels 4 11-01-2007 07:25 PM
pro comp davenjit Tires & Wheels 1 08-18-2006 07:46 PM
Pro comp M/Ts? 1234JeepinJordan Tires & Wheels 12 06-26-2006 02:26 PM
Pro Comp Knight1989 Tires & Wheels 1 09-21-2004 10:38 PM
