Painted Ravines - Page 4 - JeepForum.com
post #46 of 109 Old 02-18-2008, 05:45 PM Thread Starter
35sUnlimited
35sUnlimited's Avatar
Originally Posted by .Jch. View Post
I realize this thread is old as junk, but I am about to do this project using the satin black from Duplicolor. My question is approximately how many cans are needed for the paint and clear coat?
So that you don't run out in the middle of doing it I'd get 3 cans of black and 4 cans of clear. You can always return them if need be, but it sucks to run out in the middle of working.
Doing several coats of clear is going to be crucial to turn the satin black glossy that is why I suggest 4 of them.
Since you are about to do this I will stress that a long lasting, good looking finish depends on the prep work. Spend more time than you think you need to sanding every little nook and crannny. If you clean them and still see a shiny spot then sand a little more and clean again. Repeat as required before painting.
Good luck and post up pics when done.
Tyler
04 LJ Pics:
Half top write-up:
Painted Ravines write-up:
35sUnlimited is offline
post #47 of 109 Old 02-18-2008, 05:50 PM
.Jch.
.Jch.'s Avatar
Thanks. I didn't want to have to run out in the middle of the project thats why I asked. The weather here doesn't appear like it'll be warm enough for the recommended temperatures so it might have to wait til another weekend, but I will have pics as soon as I do get it done. Thanks for all the words of advice and incredible looking jeep.
_____
l JEEP l
OllllllllO
2006 Unlimited
Black Jeep Club V2.0 Member #2006
.Jch. is offline
post #48 of 109 Old 07-10-2008, 10:23 PM
tjSport06
Well time to bring back an old post... I am curious if you removed the tape from the machined lip and clear coated that with the rest of the rim or if you just left it taped and cleared them.... im about to do the same thing to my ravines but am debating between charcoal or black... any input would be great... I have a bright silver metallic jeep with everything accented black...
Silver '06 TJ Sport // OYR Rear Corners // Oval L.E.D. Taillight Conversion
tjSport06 is offline
post #49 of 109 Old 07-11-2008, 06:51 AM Thread Starter
35sUnlimited
I did not re-clear the lip. If you do be sure to scuff up the existing clear for adhesion.
I think black centers would look best on a silver jeep with black accents.
Take your time, good luck, and post pics!!!
Tyler
04 LJ Pics:
Half top write-up:
Last edited by 35sUnlimited; 07-11-2008 at 10:23 AM. Reason: meant to say "good luck" rather than "good"
post #50 of 109 Old 07-11-2008, 10:02 AM
tjSport06
Take your time, good, and post pics!!!
Tyler
Thanks for the input... ... This is one of two projects i have slated for this summer... The other is installing a set of OYR corners with oval leds... I'm planning on taking detailed pics of both and starting a build thread...
post #51 of 109 Old 08-03-2008, 02:12 PM
LGriffith
Do you have to remove the tires or do it before you put the tires on? Or can you paint the wheels with the tires mounted? Thanks
LGriffith is offline
post #52 of 109 Old 08-03-2008, 07:11 PM Thread Starter
35sUnlimited
I painted mine with the tires still mounted.
04 LJ Pics:
Half top write-up:
post #53 of 109 Old 10-05-2008, 09:41 PM
Texan4life
Does anybody have a picture of ravines painted black? I'm thinking about getting my ravines out of my attic and painting them black. I think it would look good on a white LJ.
Amendment 10 -
The powers not delegated to the United States by the Constitution, nor prohibited by it to the States, are reserved to the States respectively, or to the people.
Texan4life is offline
post #54 of 109 Old 10-06-2008, 06:36 AM Thread Starter
35sUnlimited
Check this out:
http://cgi.ebay.com/ebaymotors/Parts...=p4506.c0.m245
04 LJ Pics:
Half top write-up:
post #55 of 109 Old 10-06-2008, 12:46 PM
LGriffith
Those are awesome
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
post #56 of 109 Old 10-07-2008, 10:49 AM
MCDavis
The ad says they are Cherokee wheels. Will they fit an LJ? I know they're 15/8, but is the backset and lug spacing correct?
MCDavis is offline
post #57 of 109 Old 10-07-2008, 11:34 AM
Fargo
Yes,
Scroll down a little bit further...
Fits: All: Wrangler 1991 - 2006 / Cherokee 1993 - 2001 / Comanche 1992 / Grand Cherokee
6spd manual
LJ Owners Group member #110
Fargo is offline
post #58 of 109 Old 10-07-2008, 07:44 PM
Texan4life
I'm definitely doing that. Thanks for the link.
Amendment 10 -
post #59 of 109 Old 10-08-2008, 02:23 PM Thread Starter
35sUnlimited
Post some pics when ya get it done!! Good luck and have fun.
04 LJ Pics:
Half top write-up:
post #60 of 109 Old 01-24-2009, 01:34 AM
mJUSTINm
very awesome thats exactly what i was planning on doing to mine soon. i think its gonna look amazing on my dark blue LJ. i think black rims are overdone and i dont like the lighter colored ones.. i thought gunmetal with a silver lip would look best. so glad i found this thread, it definitely made up my mind!
mJUSTINm is offline
32x11.5's on ravines SOLIDJP44 Tires & Wheels 4 08-02-2009 08:41 AM
can I put these on ravines? Also... Longspoon Tires & Wheels 1 07-02-2008 09:30 AM
33x10.50 BFG MT on Ravines mikey6345 Tires & Wheels 8 09-04-2007 08:04 AM
Painted Ravines Wazinga Tires & Wheels 6 09-03-2007 05:17 PM
Ravines and 33x12.5 cdsptatc Tires & Wheels 0 09-01-2005 09:38 AM
