Painted Moab wheels satin black...pics included - Page 2 - JeepForum.com
post #16 of 29 Old 10-11-2009, 11:54 AM Thread Starter
tufmar
Originally Posted by BoundlessBinder View Post
Good looking bruised Jeep (black & blue)
Haha, yea it definatly took on the nickname of "bruiser" after I finished. In reference to the prep work that I did...I simply sanded the clear coat finish using 320 grit until they were dull and nice and smooth. Sucked all the dust up with my shop vac and cleaned them thorougly with Acetone. Then I put several light coats of self-etching primer and let that set for 30 minutes or so before I applied multiple light coats of the satin black (waiting 5 or so minutes in between coats ). I don't have any painting experience either but just took my time, which was also a challenge because I lack patience too. Sanding has to be one of the worst jobs, IMO, but if you put in some good elbow grease time and clean them really well you should get good results.
93 YJ - 4.0 2" BDS 1" BL 33's
98 ZJ - 5.2 Limited 2" BB 31's
02 WJ - 4.7 Laredo 242 TC 3" IRO 245/75's
tufmar is offline
post #17 of 29 Old 10-11-2009, 01:01 PM
jondotcom
Cool thing about rattle-can paint is that if you get buyers remorse on the color, you can go back to the factory aluminum look with a bunch of rags and acetone (and hopefully the appropriate ventilation). Of course you'd have to re-clear if you dulled the factory finish.
jondotcom is offline
post #18 of 29 Old 10-11-2009, 01:08 PM
Bennettj13
Hopefully it holds up alright. Aside from the normal rock gashes and scratches, I want the paint to stick. Thanks for the heads up man.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #19 of 29 Old 10-11-2009, 03:08 PM
ProjectWhiteTJ
looks great, i love that color of your jeep
ProjectWhiteTJ is offline
post #20 of 29 Old 10-12-2009, 06:58 AM
Boundless
Agreed it was a long day when I did mine, but soooo worth it
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
Boundless is offline
post #21 of 29 Old 10-12-2009, 05:40 PM
southtxdstroyer
i believe the gray top came on only one year of the unlimiteds............... maybe 05?
i dig the wheels
ive kicked around painting my moabs black as well
i want to trade my black hard top for a gray one
i think it would look sharp, especially with gray fender flares
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant, 'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honor.
open your eyes
southtxdstroyer is offline
post #22 of 29 Old 07-15-2010, 03:23 PM
UncleWilson
UncleWilson's Avatar
How are the wheels holding up over time? Also, did you unmount the tires from the wheels or just tape it off?
2006 LJ Rubi JKS BL/MML, Curries Arms, 3", UCF Skids, Riddler, 35 GY MTR W/K, Black Rock 909's, Black Magic, Rokmen Sliders, Savvy GTS, Cloaked, 4.88
o[__Q_]o
(OIIIIIO)
[]==O==[]
UncleWilson is offline
post #23 of 29 Old 07-19-2010, 07:11 AM
mooseknuckle
x2....have classic II's that are a little worse for wear and wanted to paint black.
Also, how long until the paint is dry enough to put back on? I've learned via my front door of my house that although paint is dry to the touch, it's not fully cured for a while....at least that's what my weatherstripping told me....
So, with the rattlecan, how long until it's good to go?
mooseknuckle is offline
post #24 of 29 Old 07-19-2010, 06:23 PM Thread Starter
tufmar
Wow, my old wheel thread raised from the dead.
UncleWilson--Got your PM, in reference to your question...They are holding up perfect, better than I thought they would. They barely have a nick on them and look like day 1. It just goes to show you that solid prep work goes along way.
I did not un-mount the tire/wheel(s). With the way my moabs and BFG's mated, I was able to get the tape to sit just a hair under the lip of the wheel, preventing any over spray onto the tire.
For dry/cure time: I probably waited atleast a good 24 Hrs with each wheel after it was done before I re-mounted them. The rattle can I used dried pretty fast.
tufmar is offline
post #25 of 29 Old 07-19-2010, 06:40 PM
UncleWilson
Thank you for getting back to us. That is so cool. After you primed and painted, did you clearcoat as well? I'm excited to make the moab's to look even better
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #26 of 29 Old 07-19-2010, 07:18 PM Thread Starter
tufmar
No clear coat, that is why I went with the satin finish. A happy medium between flat and Glass IMO.
tufmar is offline
post #27 of 29 Old 08-18-2010, 03:38 PM
UncleWilson
Did you just do the outside face or the inner too?
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #28 of 29 Old 10-16-2013, 10:24 AM
ejslacker
1982 CJ7
Looks great I think im going to do mine this weekend
ejslacker is offline
post #29 of 29 Old 10-25-2013, 08:59 AM
Dukcaln
think I am going to do my wife Durango wheels like this. I like the satin black and didn't want to pay the cost of powder coating!
1996 zj-v8-79k miles-corbeau seats-exhaust-hood vents-3 1/2 lift-safari rack-arb bumper-amps-subs
Dukcaln is offline
Paint my moab wheels black? grymsr TJ Wrangler Technical Forum 37 07-19-2011 01:23 PM
Ecco wheels painted black? jimaug87 Wrangler General Discussion 2 06-21-2008 11:09 AM
Got rims today...pics included. Black steelies. JeepinYahoo TJ Wrangler Technical Forum 7 04-24-2007 08:36 PM
Painted my fenders black! Pics Ayankees2772 TJ Wrangler Technical Forum 5 03-23-2007 10:11 PM
painted roll cage black...PICS! blakkbelt YJ Wrangler Technical Forum 2 05-25-2006 02:44 PM
