Quantcast Opinion on Tires - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Opinion on Tires
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 12-02-2002, 08:17 PM   #1
jasonamorris
Opinion on Tires
Ok, I just want a few more opinions...
I want to put a 3'' body lift on my 87 wrangler, I am getting 15x8 rims and my friend has 33x12.50 tires. Will all that work ok or not?? If not, then what will 15x8 rims with 31x10.50s look like? with a 2'' lift?? or should I go with a 3'' lift with the 31's??? PLEASE help me out, I'm having trouble
jasonamorris is offline   Reply With Quote
Old 12-02-2002, 09:01 PM   #2
rustyCJ
a 3" body lift alone wont clear 33s. the 33x12.50s will fit on the the 15x8 rims. it sounds like you trying to get the biggest tires under your jeep the cheapest you can. sorry but that only leads to problems in the long run. you gonna have to get some lift springs to run the 33s, if you want to run the 31s, get addaleafs and at the most a 2" body lift. i personally wouldnt use a body lift at all.
[COLOR=darkgreen]"character is doing the right thing even if nobody is looking"[/COLOR]
rustyCJ is offline   Reply With Quote
Old 12-02-2002, 09:09 PM   #3
jasonamorris
Ok, what about if I go with a 4'' lift with the 33's and the 15x8 rims???
Old 12-03-2002, 07:01 PM   #4
demtjcj
you could do that
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline   Reply With Quote
Old 12-17-2002, 08:48 PM   #5
ErikJordan
Pimp Hand
ErikJordan's Avatar
if you off road and flex your jeep, you'll need a 4" susp lift, and a 1" body lift.... you still may rub on occasion, i do.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline   Reply With Quote
Old 12-18-2002, 06:07 PM   #6
tj2kbob
I worry about going to high on the body lift. Heard to many stories
( just that stories never seen it happen) about making the body bolts weak etc. Plus the first time you attempt to really flex as said before..you will rub. I run 36's on a 4 in susp. lift and a 1in body lift. And to tell you the truth, I am going to go a little higher on the susp lift, just for good measure..
See the Black Jeep here
[url]http://community.webshots.com/user/tj2kbob[/url]
tj2kbob is offline   Reply With Quote
Old 12-21-2002, 11:43 AM   #7
XtraWorm
3" Body lift WILL clear for 33's, as long as your wheels are neutral offset and your springs are in good shape. However, I highly recommend a suspension lift instead, a 3" plus bigger shackles will suit you nicely. Body lifts do nothing for suspension performance, suspension lifts give you better articulation. You'll probably need extended brake hoses, too. After that, a 1" body lift and bigger fender flares will help adapt the changes (you might get a ticket if your tires stick out too far from your current fender flares).
XW
XtraWorm is offline   Reply With Quote
Old 12-21-2002, 12:17 PM   #8
ErikJordan
Pimp Hand
ErikJordan's Avatar
i beg to differ on the shackle lift! shackles are crap. i tried them and it dcanged the handeling of the jeep soooo much that they wer on there just long enough for me to get the money together for springs. DO NOT GO SHACKLE LIFT i know i'm not alone on this one! you can easiliy get lifted properly (with springs) for $300-350.00. 4 wheel parts has the 4" pro comp springs out the door for $225.00. remove 1 leaf from the rear pack and the ride will smoothe out, and flex better. with my application, i put 3/4" solid stock as a spacer to lower the x-fer case. i have no vibes, and with the 1" body lift can clear the 33" tires at full articulation.
i've been a number of different routs wit this suspension crap. save yourself some money.... do it right once instead of buting crap you wont like, and redoing it next week. you'll hear a lot of negative things about the pro comp lift, but removing one leaf fixes these problems......
good luck!
Old 12-21-2002, 05:21 PM   #9
93jeepyj2.5
I agree, I dont like shackle lifts either.....but I dont believe the word shackle has been brought up in this thread before you said it????
I also dont like my body lift either, but it was on there when I bought my Jeep. When I bought it, My Jeep had a 3" BL and 33X12.5 and they did rub, but they did fit.
-Heath
BTW.....this is my 1000th post
93 Black YJ, locked and on 33's----Sold
03 TJ Sport.....31" MT/R's on MT Classic II's
93jeepyj2.5 is offline   Reply With Quote
Old 12-21-2002, 06:33 PM   #10
ErikJordan
Pimp Hand
ErikJordan's Avatar
hmmm either i'm loosing my mind, or xtraworm edited his post from shackle lift to suspension.....
i dont know.... anyways, shackles suck?!
LOL!
Old 12-21-2002, 06:42 PM   #11
XtraWorm
No, my post still mentions "bigger shackles". I do like mine, however. I used 1.25" lift shackles, and I have not noticed any negative effects in my articulation. Sometimes people put too much torque on the shackle bolts, which causes them to bind....
Anyway, difference of opinion I suppose.
XW
'94 2.5L SuperRide 1.5, Shackles, disconnects, rs5000's, 15"x 8" steel, 32"x11.50" BFG AT, header, exhaust, elec. fan, ignition, SYE, TJ front axles, full poly, full stainless hardware, and lots of tough love.
Glock Forum
