OME lift question (track bar relocation bracket) - JeepForum.com
post #1 of 11 Old 12-07-2005, 08:42 PM Thread Starter
cathellsk
My dealership, who lifts alot of Jeeps and they do alot of wheelin' so I'm inclined to trust what they say, just put my OME lift on. When I went to pick it up I found out they didn't install the trackbar relocation bracket with my lift. The only mods I have done are the basic OME lift and a set of 32s. IIRC he told me I wouldn't need it unless I went with a bigger tire or further mods. Is this something I need to go back and have put on or is there something else, like an adjustable one, that you guys would recommend? Please help, as I'm just learning all this stuff.
"When you go home, Tell them of us and say, For your tomorrow, We gave our today."
'04 Electric Lime Green LJ (my John Deere), auto, softop, 2.5" OME, 32" BFG ATs on Cragar Soft 8s, Rubicon flares, 40 series Flowmaster, etc.
cathellsk is offline
post #2 of 11 Old 12-07-2005, 10:20 PM
BobboTJ
Not being familliar with your kit, I would still assume if it came with the kit that it should go on. By basic OME, you mean the 2.5" lift? Is this your rear trackbar? Measure how much your tires are out from the flares and if not equal then your axle is off (compare rear to rear, front to front)
'97 TJ Sport....I take care of her and she takes care of me
-3" Full Traction
-33" Kumho MT
-Black Steelies
-Custom Fabbed Front Bumper
-Herculined Tub
Comin soon-4.10's, 1" BL/MML, Skids
BobboTJ is offline
post #3 of 11 Old 12-07-2005, 10:31 PM
JBXdudeTJ
I'll probably have an answer for ya tomorrow. I screwed up the bracket the other day doing an OME install...Having things reversed and reinstalled haha. Anyway, learn from my stupidity and if you do it...be sure ur doing it right, not a lot of room to screw up! But i'll ask the fellas tomorrow at high country 4x4.
Golden Eagle TJ Project (2005 TJ - 2.4l)
HID Boobie lights
Mickey Thompson Classic Locks
OME Lift
BGF AT's - 33's
Parrothead Jeeper Union member #26!!
JBXdudeTJ is offline
post #4 of 11 Old 12-07-2005, 11:55 PM Thread Starter
cathellsk
Your correct, its the 2.5" kit.
And, yes, my rear axle is off. Its more shifted to the passenger side by about an inch or so. As a matter of fact, the front axle looks like its off to the driver's side but not as bad as the rear.
I assume thats what the rear trackbar relocation bracket is for? Is it going to hurt anything if I don't go back and have it put on? As soon as I picked my LJ up I went to SEARS and had an alignment done btw.
post #5 of 11 Old 12-09-2005, 04:10 PM
BobboTJ
If it is off in the rear, I would definitely take it to that shop and tell them to put it on free of charge.
-3" Full Traction
-33" Kumho MT
-Black Steelies
-Herculined Tub
BobboTJ is offline
post #6 of 11 Old 12-09-2005, 04:51 PM Thread Starter
cathellsk
Sorry, forgot to update the situation. I did go back to the shop yesterday and they are putting on the trackbar relocation bracket Monday morning.
Does anyone know if I'll have to get the alignment checked again after they do this?
post #7 of 11 Old 12-09-2005, 06:34 PM
TellyDSP
Poland and PPV!!!!
I've always been told to get an alignment after a lift.
And BTW, why would getting bigger tires be more reason or any reason to put the trackbar on. Either the axle's centered, or its not. The size of the tires shouldn't make a difference.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #8 of 11 Old 12-09-2005, 06:53 PM
jaburk
jaburk's Avatar
You don't need your alignment checked. As far as your front end alignment goes, the only thing that is adjustable on your Jeep is toe in which can be easily done yourself. Your throwing your hard earned $$$ down the drain by paying someone to set your toe in.
http://www.4x4xplor.com/alignment.html
1998 XJ, RE 3.5" Lift
jaburk is offline
post #9 of 11 Old 12-09-2005, 07:51 PM
backwash
The reason they did not put the rear trackbar bracket on is that it it the only part of that lift that is hard to do. It requires an angle drill and it's hard to get into. Then you need little girl fingers to thread the new bolts in. Good thing you caught them. You want the rear axle centered.
2004 Red Unlimited , hard & soft tops, 4.0 Auto. Alpine,
OME 2 1/2 Lift, BFG A/T 32x11.5 ,AR Diamond locks. JKS Quicker disco's. Kilby Skid. Cobra 75. Rokmen sliders. ARB Front and rear. Hansen bumper. Warn 9.5ti winch. Currie trackbar,Skid row engine & gas tank skids
Nth Degree tummy tuck, 1" BL
backwash is offline
post #10 of 11 Old 12-09-2005, 09:02 PM
jaburk
jaburk's Avatar
You hit the nail on the head.
jaburk is offline
post #11 of 11 Old 12-10-2005, 11:44 PM
kingkawi
front track bar relocation?
I just installed a 3" lift from 4wd hardware today and in the instructions it also said that you needed to drill a new hole for the front trackbar as well, i did do it but i did not check to see if it was centered, i will do that tomorrow. I also have to align it tomorrow cause on my test ride i got the "death wobble". thank to the post above with the instructions on adjusting the toe in and such i think i may be able to correct it... i'll come back after doing so and post my findings. Has anyone else drilledthe hole for the front track bar... I'm also new to the forum, i started browsing about a week ago just looking for tips on putting in a lift because this is the first one im doing. I found this forum to be very informative, I'm glad to now be a part of the forum, thanks!!
chris
kingkawi is offline
Seat relocation bracket? SidewaysTim Fabrication Shop 6 11-01-2007 07:28 PM
Track Bar relocation Bracket beyondink Tires & Wheels 2 05-23-2006 08:33 AM
Trackbar Relocation Bracket Jailor Tires & Wheels 3 09-30-2004 03:08 PM
brake line relocation bracket KU krawler Tires & Wheels 0 07-21-2003 10:31 PM
Track bar relocation bracket for 2" budget boost UH60Hwkdrvr Tires & Wheels 3 01-27-2003 12:41 PM
