Nth Degree 4.5 inch Short Arm - JeepForum.com
post #1 of 22 Old 09-17-2006, 05:53 AM Thread Starter
numchuck
pirate squirrel
numchuck's Avatar
Has anyone considered this lift kit? . . . I had wanted to get their long arm kit . . . but I am a wuss - and I don't really want to cut off the original control arm frame brackets --- that just seems like too much commitment --- long arm kits are also more expensive; and since I'm really just a "poser" it's hard to convince myself to put so much on the credit card .
- Chuck -
the "Dude" abides
numchuck is offline
post #2 of 22 Old 09-17-2006, 07:59 AM
ISurvivedNMU
I have been spending my last weekend getting the Rubicon Express 4.5 Super Flex kit installed. I might be wrong, but the RE kit gives you adjustable upper control arms. They are needed for a 4.5 kit! With that said, the RE kit is missing hte shock shifters... So the price is about the same, but i think you get more with RE. Contact some vendors on here, and you can get it at an even better price.
2006 Jeep TJ Rubicon... Currie 4" Lift, ect...
2011 Grand Cherokee Overland
2015 JKU Hard Rock
ISurvivedNMU is offline
post #3 of 22 Old 12-13-2006, 08:47 PM Thread Starter
numchuck
pirate squirrel
numchuck's Avatar
Today, after many weeks, I finally took the plunge, and ordered the lift . . . I feel guilty . . . but I'm tired of lusting after others tall jeeps . . . Chris Velasco, at Nth, was very helpful, and explained the pros and cons of different systems ( actually there don't seem to be any cons with their systems other than $$$ ) . . . anyway I'll post pictures soon
- Chuck -
the "Dude" abides
numchuck is offline
post #4 of 22 Old 02-04-2007, 08:30 PM Thread Starter
numchuck
pirate squirrel
numchuck's Avatar
I started the install this weekend . . . but after 2 long days I'm still not done . . . everything went fairly smooth . . . but I had to do some drilling and cutting . . . the rear is done except for cutting away the original shock brackets from the axle and re-welding new ones . . . hopefully, tomorrow, that will be done, and I can start on the front
- Chuck -
the "Dude" abides
numchuck is offline
post #5 of 22 Old 02-11-2007, 07:20 PM Thread Starter
numchuck
pirate squirrel
numchuck's Avatar
done with lift; but not with tires . . . stock will have to do, for now, while my credit card recovers
- Chuck -
the "Dude" abides
numchuck is offline
post #6 of 22 Old 02-11-2007, 10:45 PM
barry1me
barry1me's Avatar
looks good cant wait to see it with some bigger tires!
Sport TJ build
everything below has a hyperlink to the install/review
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline
post #7 of 22 Old 02-11-2007, 10:56 PM
ptowntj
ptowntj's Avatar
Doesn't too bad with the stock tires...congrats
and I do know the feeling of being in a stock jeep, I hated seeing all the other lifted jeeps around, and my credit card is also recovering from it too. But its worth it!
8 lug xj.
ptowntj is offline
post #8 of 22 Old 02-12-2007, 07:25 AM
Muddeprived
Muddeprived's Avatar
How's it ride on the street? (stupid question i know) I'm wondering cuz short arm lifts above 4" get a steep control arm angle and ride a little rougher. Dunno about Nth's though....
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #9 of 22 Old 02-12-2007, 07:49 PM Thread Starter
numchuck
pirate squirrel
numchuck's Avatar
the Nth Degree system handles great . . . seems even more stable than stock . . . small bumps seem softer; but large bumps seem harder . . . but to lessen the angles of the rear lower control arms, the kit comes with a template, to locate and drill new holes, in both the axle brackets and the frame brackets (see third photo below) also, there are new brackets included that raise the attachment points of the trackbar and the rear upper control arms to the axle
- Chuck -
the "Dude" abides
numchuck is offline
post #10 of 22 Old 02-12-2007, 08:06 PM
Muddeprived
I had no idea they re-located the arm bolts. That's the coolest thing. I'm wondering why other kits don't do the same. I wonder if i can do that with my 3.5 (approx) lift, but i'm sure im gonna have to get tubular control arms of some sort cuz the stockers are too large to move up.
If i were to do this, how would i go about doing it without a template? For the fronts, could i just disconnect the rear bolt on one side, lower it approx 1" and mark the spot with a pen and then drill a new hole? Then i'll recconnect it to the factory hole and do the other side. I could probably lower the rear of the control arm but not the front.
Are the upper arms lowered or leveled too?
post #11 of 22 Old 02-12-2007, 08:22 PM Thread Starter
numchuck
pirate squirrel
numchuck's Avatar
don't mess with the fronts . . . Nth says that doing that will cause other, more complex handling issues . . . look at my last photo and notice how I cut out a half moon shape in the axle bracket to allow more movement of the rear control arm . . . if you call Chris Velasco at Nth, he will send you a template that will work with your present setup and guide you through the other modifications . . . Nth Degree is very familiar with Rubicon Express; and many of their parts can be made to work well together . . . the upper control arms remain in the stock locations at the frame, but are moved upward, at the axle, through the use of special brackets
- Chuck -
the "Dude" abides
numchuck is offline
post #12 of 22 Old 02-12-2007, 08:27 PM
Muddeprived
Awesome. I will do this as soon as time permits. Thanks man.
Oh by the way, are the front upper arms like the rear uppers, adjustable ON the vehicle? I have the rear uppers from nth and you can't beat the ease of adjustability.
post #13 of 22 Old 02-12-2007, 08:35 PM Thread Starter
numchuck
pirate squirrel
numchuck's Avatar
yes . . . they also can be adjusted in place . . . but the front part that attaches to the axle is shaped differently . . . it is Y - shaped instead of round
- Chuck -
the "Dude" abides
numchuck is offline
post #14 of 22 Old 02-12-2007, 08:47 PM
Muddeprived
Just a heads up in case you didn't, it's best to use anti-sieze on control arms threads. I overlooked this minor detail and had to use every ounce....oh wait, you live in texas...never mind
damn salt.
post #15 of 22 Old 03-06-2007, 02:07 PM
thejafe
thejafe's Avatar
Lookin' good Chuck . I would have checked in sooner but I just came across this thread .
BTW - Did you know that the OME shocks are now available in black?? I owned a set just before I acquired my RE 3.5" kit. Thought maybe you'd be more into those than the yellow's. Just a heads up.
thejafe is offline
33 inch swampers with 2 inch rough country lift Unlimited_Ma Tires & Wheels 8 06-02-2008 09:42 PM
Nth Degree Mobility - 3rd Degree 3" - $1500 azcoyote Tires & Wheels 2 04-25-2007 01:55 PM
3 inch spring in front, 2 inch in rear ltjjdunbar Tires & Wheels 1 08-12-2006 09:29 PM
nth degree gyro-joint SHORT-ARM kit? Jr KLR Tires & Wheels 3 04-30-2006 04:31 PM
2.5 inch suspinsion lift plus 1 inch shacklel the shootist Tires & Wheels 3 11-19-2002 08:16 AM
