Novice Tire advice needed! - JeepForum.com
post #1 of 3 Old 04-29-2013, 02:39 PM Thread Starter
iamfuller
Help! I need advice. I have a 2009 Jeep GC that has roughly 75,000 miles on it. I bought all new tires this past September. In March, I had a low tire pressure light come on so I took it in for oil change, tire rotation, and told them about the low pressure light. They neglected to fix the problem -- told me I had a slow leak. Well it wasn't so slow because Monday morning I had a flat tire. I had AAA come and change the flat to my spare and dropped the tire off at the dealership for them to evaluate the tire. They said they fixed it-- that it was leaking air between the seal. Fast forward, 3 weeks, my light comes back on. I take it in this past Saturday and I am told they have to replace the tire pressure sensor and this is their evaluation "replace tire pressure sensor in right rear wheel in between the rim and where the valve stem (tire pressure sensor) is inserted is no longer keeping seal"
So not knowing if I have any other option than to fix it, I say go ahead -- total cost $217.95
I am no car expert or mechanically savvy whatsoever, but did I just completely get ripped off? I am mad to begin with because their customer service sucks and this will be the 3rd time I have taken it in for the same reason -- low tire pressure and the fact that the tires were brand new in September and purchased from them. They are under warranty, but apparently this isn't something covered under the warranty.
Any suggestions on anything I can do or is this just life?
Any help is MUCH appreciated. I am supposed to pick it up today so I would like to know what questions I need to ask if any or I just need to cut my losses.
iamfuller is offline
post #2 of 3 Old 04-29-2013, 04:20 PM
brouwmat
Sounds about right from the stealer.. I mean dealer :-), probably $50 for the part, minimum of an hour labor at $100 and $50 for setting it up (I think there is some programming involved to get it to work properly). You probably could have gotten it done for less at a tire store or an independent. The tire really has nothing to do with your issue and they need to remove it to get at the sensor to replace it. I have complained about stuff like this and gotten them to knock $50 or so off.. Really depends on who the dealer is. You might enable to convince them if you demonstrate that you know it didn't take an hour to perform the task.
brouwmat is offline
post #3 of 3 Old 04-29-2013, 04:24 PM
wlo2000
Is the Jeep under warranty? I'd ask them to split it with you since you had to pay for the towing service (AAA or not) and you only had to get the AAA help because they misdiagnosed it in the first place. My $.02.
wlo2000 is offline
