new tires? Where to put (2) new tires, front or rear? - JeepForum.com
post #1 of 5 Old 10-19-2011, 10:10 PM Thread Starter
JPetru82
JPetru82's Avatar
not sure if this is where I should be posting this, but it seems like a good place for it. I have an '01 wrangler, and I kind of messed up. When I bought my lift kit, I bought four new tires, plus a full size spare. The part where I've messed up is that I've never rotated my tires. I know, that's my bad. Well, now the front two tires are pretty worn, and should be replaced soon. Do you think I should move the rear tires forward, and put the new ones on the rear? or buy one new tire, and put that one and my full size spare in the rear, and then move those forward, and keep one of the worn tires for a spare?
Thanks in advance!!!
JPetru82 is offline
post #2 of 5 Old 10-20-2011, 06:23 AM
mdm
Farm Wheeler
I'm guessing you are happy with the type of tire you have now and will be buying the same tire again. You don't say how much wear you have on the rear tires.
I would most likely buy three new tires, this plus the unused spare gives you a full set of new tires. Keep the best "old" tire for the spare.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 5 Old 10-20-2011, 01:07 PM
BlackBellamy
BlackBellamy's Avatar
Whatever you do from now on make sure you do a five-wheel rotation. This way your spare will never be the odd tire out.
Use the Rearward Cross method.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #4 of 5 Old 10-20-2011, 09:23 PM
dcorn
When I wore out the front tires on my XJ, I bought two new ones, moved the rears to the front and put the new ones in the back. After this, start rotating better.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #5 of 5 Old 10-21-2011, 12:53 PM
terpsmandan
2009 JK Wrangler
If you are only swapping two tires, put the ones with more tread on the back. Reason why is because if it is slick, it is easier to control if the front end starts to slide before the back.
terpsmandan is offline
new tires.. Front or rear? slafferty Wrangler General Discussion 11 04-20-2010 07:52 AM
Which tires wear faster on a TJ, front, or rear? saxart TJ Wrangler Technical Forum 16 10-08-2009 02:25 PM
Cat back in front of rear tires jungleplant TJ Wrangler Technical Forum 16 02-19-2006 04:37 PM
Duals In front of Rear Tires idgit0488 TJ Wrangler Technical Forum 15 11-27-2005 02:33 PM
Which tires wear faster - front or rear? cleger TJ Wrangler Technical Forum 7 01-15-2005 02:05 PM
