New jeep steering probs - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > New jeep steering probs
NOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military Disc
Unread 07-26-2008, 05:38 AM   #1
1FSTLS1
Just got a jeep for my wife last night. 2000 wrangler. Has 4in skyjacker suspension lift and 33x12.50 tires. Steering is whorable. Is this a common problem what should I be looking for?
1FSTLS1 is offline   Reply With Quote
Unread 07-26-2008, 11:01 AM   #2
p-rev
whats bad about it? too stiff or too squirly? bumpsteer?
p-rev is offline   Reply With Quote
Unread 07-26-2008, 03:41 PM   #3
1FSTLS1
Way too much play in the steering. I just got done putting in all new ball joints and drivers side front hub/wheel bearing. Not sure if I want to test idrive t incase that was not the fix.
Unread 07-27-2008, 08:54 AM   #4
Pillswoj
Have someone turn the steering wheel back and forth while you watch the components in the front steering / suspension, Check for play in the Draglink, tie rod and trackbar.
Also check the control arm bushings, when I bough my 99 it had the Skyjacker 4" and I had to have all the control arm bushings and the rear trackbar bushings replace (as well as Balljoints and unit bearings) once I had that done it drove great.
Friends don't let Friends run Bosch
Pillswoj is offline   Reply With Quote
