New Jeep Owner - Tires? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > New Jeep Owner - Tires?
XJ guys, clock your transfer case!Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-29-2007, 11:49 AM   #1
thunk
Howdy...i pick up my 02 Wrangler Sport this week. It needs some new rubber. From the research i have done, it seems the BF All Terrains are the good ones. When I look them up online, I always see the 30x9.5 listed as the tire size for the jeep. but i also see posts of guys putting on 31x10.5. are the 31's really much better thand the 30's
Thanks
thunk is offline   Reply With Quote
Unread 05-29-2007, 11:53 AM   #2
mdm
Farm Wheeler
The reason you see so many people running the 31x10.5 is that it is the largest tire you can run on a stock TJ. You might get some rubbing on the lower control arms at full turn which is easily fixed.
http://www.stu-offroad.com/steering/...teerstop-1.htm
mdm is offline   Reply With Quote
Unread 05-29-2007, 12:56 PM   #3
HowUDerin
my 30's have never given me a problem. although i have gotten stuck before, my 30" bfg at's have carried me through the same spot as some xj's on 32's and 33's. i'm gonna try some Kumho Road VENTURE MT in 30" next because: i cant afford the lift just yet, my 30" have only ever let me down twice so far(in bumper level mud mind you), and because those kumho's are cheap and have good reviews on tirerack.com...many of said reviews by jeeps.
as far as going to 31's...up to you, but my 30's have done me just find for my 95% on road dd and just fine during that 5% off road trips.
HowUDerin is offline   Reply With Quote
Unread 05-29-2007, 01:01 PM   #4
hikerpaddler
30's are fine. 31x10.50x15's definitely look better, but if you're unlifted and discoed, you'll lose some articulation off-road. For moderate offroading, both 30's and 31's will work. There are a number of quality a/t tires available. BFG's are the most popular for street/light offroad use. The best quality a/t out there right now is the Bridgestone Dueler Revo. Top of the line, and utterly silent on the interstate.
hikerpaddler is offline   Reply With Quote
Unread 05-29-2007, 01:14 PM   #5
Jon_H
I have 31" BFG A/Ts and they're great. They're better than 30"s because they give you a little more ground clearnance, and personally I think they just look better. I am thinking about going with 31" BFG M/Ts soon though, they have a more aggressive look and would probably do a little better on the trail.
To steal a picture (this is not my Jeep)...
( Stock Suspension with 31x10.5x15 Dayton MT Tires )
Jon H.
'97 TJ Sahara | 31" BFG A/Ts | Dynomax exhaust system
Stock Jeep Club Member #36
Silence is golden, but tape is silver.
Jon_H is offline   Reply With Quote
Unread 05-29-2007, 01:24 PM   #6
grogie
My Rat Bastard
grogie's Avatar
Thanks
You might also look at REVO's for either size (see the link below). I run them on both my Jeeps (at least until I can afford new wheels and tires for the TJ... as I plan to go to 32's).
http://www.jeepforum.com/reviews/sho...uct=275&cat=31
Red Jeep Club #345
2006 TJ Sport
2004 KJ Limited
2012 John Deere D140
2013 Junior
Rat Bastard | rat bas-terd |
noun
Of doubtful chronological and geographical grounds; questionable ancestry; mixture of manufactures.
“The only thing that stops a bad guy with a gun is a good guy with a gun.”
grogie is offline   Reply With Quote
Unread 05-31-2007, 10:04 AM   #7
thunk
yeeehhaaa
I pick up my new (to me) 2002 wrangler tomorrow. Thanks for the tire info. I think I am gonna go with the BFG AT 31's. One more question....are the stocks rims ok, or is it worth the $$$ to upgrade the rims?
thanks
-Thunk
Unread 05-31-2007, 10:16 AM   #8
Crashnburn80
thanks
-Thunk
Your stock rims are likely much higher quality than any aftermarket rim you would buy. If you like them, keep them. I kept mine when upgrading my tires.
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Unread 05-31-2007, 11:23 AM   #9
Jon_H
This is what the BFG AT 31's look like on my stock gambler wheels (stock height)...
pretty nice if you ask me.
Jon H.
Unread 05-31-2007, 11:30 AM   #10
ryobi
The stock rims are fine. Revos are a lot better tire than the BFG's, but if you can get BFG's a lot cheaper, go for it, they'll be fine.
thanks
-Thunk
ryobi is offline   Reply With Quote
Unread 05-31-2007, 12:32 PM   #11
nat441
Here are 32x11.5xr15 BFG AT's on stock Gambler's with 5.25" backspacing........NO LIFT!
nat441 is offline   Reply With Quote
Unread 05-31-2007, 07:42 PM   #12
Black03TJ
i was in the same boat about a month ago buying an 03 sahara with bald tires. i did my research and purchased 5 31x10.50r15's and so far still very impressed with the tires. sam's was the cheapest place i could find
[B]UNDER CONSTRUCTION[/B]
Black03TJ is offline   Reply With Quote
