need non-jeep advice from jeep-ers on mild lift for son's '83 bronco - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > need non-jeep advice from jeep-ers on mild lift for son's '83 bronco
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!
Unread 06-02-2007, 05:39 PM   #1
numchuck
pirate squirrel
numchuck's Avatar
need non-jeep advice from jeepers on mild lift for son's '83 bronco
sorry to ask here . . . but I trust you guys most . . . my son, being less enlightened than us, has been driving an "83 Ford Bronco . . . the springs are tired and need to be replaced . . . but since the previous owner had put on 35 inch tires and re-geared the axles, I thought we should lift it just a small amount . . . 4 inches or less . . . can any of you tell me who makes the best small lift for this older truck ?
- Chuck - Nth Degree 4.5" short arm the "Dude" abides
numchuck is offline   Reply With Quote
Unread 06-02-2007, 05:43 PM   #2
nicolas-eric
take a look at http://roughcountry.com they have good lifts for broncos and they aren΄t to expensive...
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines
Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA
12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan
Jeep TJ Runicon Pics www.timbercrawler.de
nicolas-eric is offline   Reply With Quote
Unread 06-03-2007, 07:59 AM   #3
numchuck
pirate squirrel
numchuck's Avatar
thanks very much for that link . . . I read about their kits . . . but for the rear ROUGH COUNTRY uses blocks and/or add-a-leafs . . . does anyone know where to buy new leaf spring assemblies ( even if they're stock ) ?
Unread 06-03-2007, 09:01 AM   #4
Double Dog
Back from da stinkin' box
Double Dog's Avatar
Be careful with some of those kits, they sacrifice ride for lift. Get one with variable rate, or rock crawler springs and don't lift it more than 3" or you will get into another host of problems and expenses aka "Lift Cycle of Cash".
Double Dog is offline   Reply With Quote
Unread 06-05-2007, 08:50 PM   #5
numchuck
pirate squirrel
numchuck's Avatar
thanks for your guidance . . . that sounds vaguely familiar
