Need a little advice - JeepForum.com
post #1 of 6 Old 04-05-2006, 02:14 PM Thread Starter
mferrari
DelmarvaOffroad.com
mferrari's Avatar
Back round: 98 TJ Sport. D30 and D35 with 3.07s. 3 Speed Auto. I already have a 1" BL
My plans are to get a RE 4.5" SF. 35" Tires (maybe 37s in the future...)
Axles:
I am going to be getting a Ford 8.8 with disc, LSD, and 4.10 gears. I will be having a shop weld on a bracket kit to fit it onto the TJ... I will at the same time have the shop re-gear my front to 4.10s and possibly add in a lunch box style or selectable locker (fund permitting)...
Suspension Wise:
I am going to order the RE 4.5" SF kit with monotubes...
QUESTION TIME:
Once I install my suspension and axles and everything can I just do a T-case drop with a MML to cure the vib until I purchase a belly-up skid and then convert to a SYE and longer driveshaft?
Does the 4.5" SF kit come with everything I need for the lift (minus shocks which I know)?
Do yal think a 4.5" SF kit with a 2" spacer up front and 1" spacer in the rear and a1" BL is going to be too much lift for 35s?
Any thing else yal reccomend me look into or anything? I am just trying to get all my questions answer before I drop all the money.
Last Two:
Do you all think the 4x4 Group Buy is a good deal on their RE 4.5" SF Ultimate package?
1-RE 4.5" Superflex kit;
1-Short Shaft Kit from Advance Adapters;
1-Tom Woods CV Custom Drive Shaft;
1-Daystar 1" Body Lift;
1- 1" Motor Mount from M.O.R.E. (Rubber Bomb Proof);
4-Goodyear 35"12.5" R15 MTR's;
4- Black Rock Crawler Rims;
For $2,800
How much do yal think I could get for my current suspesion/wheel/rear axle setup (see sig)
Michael Ferrari
Team 120 - DOR Racing - Racing for Operation Homefront
Operation Homefront (OHF) provides emergency financial and other assistance to the families of our service members and wounded warriors.
Thanks to our Sponsors:
Delmarva Offroad - F-O-A Shocks - BD Turnkey Engine - Under Cover Fab - Jer-C Transmissions - Quigley Driveshafts
You call it rolling, we call it R&D! 443-951-JEEP
mferrari is offline
post #2 of 6 Old 04-06-2006, 04:15 PM Thread Starter
mferrari
DelmarvaOffroad.com
mferrari's Avatar
anyone????
Michael Ferrari
mferrari is offline
post #3 of 6 Old 04-06-2006, 09:59 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
Axles:
Suspension Wise:
QUESTION TIME:
I'd say no...you'll have over 5" of lift from the RE 4.5" kit...
yes, but I'd upgrade to having all 8 control arms be adjustable
I think it's way too much...no spacers needed...you can run 35's on RE 3.5" springs and a 1" BL with no problem...
see answer above about adjustable control arms...might want to consider chromolly shafts...ARB for the front...
Last Two:
For $2,800
possibly...I've always had good dealings with Jason at 4x4GB...
but, I'd check with a couple of the vendors here and see if they can match/beat it...
the rear axle ain't worth much...'cept to sell the shafts as spares...
might get a couple hundred total for the rest...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #4 of 6 Old 04-07-2006, 05:57 AM Thread Starter
mferrari
DelmarvaOffroad.com
mferrari's Avatar
Thanks, I figured in upgrading to adj LCA and also getting rear shock relocation brackets as well.
Yal don't think a T-case drop will work for a month or two?
Michael Ferrari
mferrari is offline
post #5 of 6 Old 04-07-2006, 11:04 AM
BigWaylon
tubework is cool...
BigWaylon's Avatar
for that much lift...you'd probably need a 2" MML and a 2" t-case drop...
Greg
post #6 of 6 Old 04-07-2006, 11:59 AM
Patton
Leave out the coil spacers and do the sye immediately after.
Patton is offline
In need of advice... sax_man424 General Jeep & Off-Road Equipment 2 06-12-2009 08:44 PM
advice please!! Feimer74 Audio, CB & Ham Radios, GPS, & Electrical 3 06-22-2008 10:15 AM
Need CB with PA advice matt0369 Audio, CB & Ham Radios, GPS, & Electrical 3 06-06-2008 09:34 AM
Need Advice 05RedRME Tires & Wheels 3 10-06-2006 08:18 AM
Hello to all...Advice tosnflies Tires & Wheels 7 11-08-2004 09:45 PM
