Need conversion help!! 265/75/16 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Need conversion help!! 265/75/16
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 05-27-2009, 08:31 AM   #1
JeepRookie01
265/75/16 equal to 31s or 32s?? Thanks in advance.
JeepRookie01 is offline   Reply With Quote
Unread 05-27-2009, 09:06 AM   #2
TJWilley
means, the tread is 265 mm wide
the side walls are 75% as talls as the tread is wide
265 X .75 = 198.75 mm
with a 16 in. rim size.
so the over-all diameter of the tire is 16" plus 2 times 198.75 mm.
1 mm = 0.0394 in, hence 198.75 mm = 7.83 in.
16 + 2(7.83) = 16 + 15.66 = 31.66 in. I'd call them 31's... just because you'll lose the 1/2 in. when you put a load on it.
TJWilley is offline   Reply With Quote
Unread 05-27-2009, 10:51 AM   #3
03silversport
265/75/R16 = 31.5X10.5
Thats what the math comes to, keep in mind every manufacturer will vary slightly
03silversport is offline   Reply With Quote
Unread 05-27-2009, 02:30 PM   #4
JeepRookie01
Cool, thanks.
Unread 05-27-2009, 07:46 PM   #5
green89yj
There are tons of tire size converters on the internet. You could use a couple just to double check the math.
Build
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline   Reply With Quote
Unread 05-27-2009, 08:04 PM   #6
fullhouse
are you talking about a tool that convert tire size? yah, there are couple in the net you just need t to be patient in searching.
fullhouse is offline   Reply With Quote
Unread 05-28-2009, 07:54 AM   #7
03silversport
Or you could just do the math with the proper formula
265/75/R16
Take 265 (width) and multiply (x) by .0394 (universal,works with any size)
and you get 10.44 which = the width of the tire
Now take 10.44 and multiply (x) by .75 (sidewall) which = 7.83
Now take 7.83 x 2 (you have 2 sidewalls) + 16 (wheel diameter) and you get
31.5 which = the height of the tire
We discoverd the width earlier (10.44) and now we just figured out the height (31.5) so we have a 31.5 X 10.5 R16
This is by far the easiest formula as opposed to the one posted earlier in this thread. Put it on a small piece of paper, stick it in your wallet and you will forever have the tire size conversion confidence that every jeeper desperately needs and wants
Unread 05-28-2009, 04:50 PM   #8
green89yj
Very nice. I will write that down. Thanks.
Build
Unread 06-27-2009, 03:48 PM   #9
stoneywaves
What would be the best gear ratio for 265 75 16.
Thanks
stoneywaves is offline   Reply With Quote
Unread 06-27-2009, 05:36 PM   #10
Mean Max
Don't poke the bear
Mean Max's Avatar
Conversion calculator here.
http://www.redrock4x4.com/tech/tire_calc.php
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 06-27-2009, 10:48 PM   #11
stoneywaves
Gears
thanks mean max I would like to know what gears should I be using to compensate for the increase in wheel size 4.10's 3.73's etc.
Unread 06-27-2009, 10:56 PM   #12
Mean Max
Don't poke the bear
Mean Max's Avatar
Use the calculators at www.4lo.com to calculate gear ratio/tire size/RPM with your current setup and then with the new gears. If you make the calculations using the stock gear/tire size you can see what the RPM's were at a given speed, and then calculate to see what gears would work with the new tire size to make it close to or better than stock.
Fill out your profile so that your questions can be answered more accurately.
If you have an AX-15 5 speed (for example) you would need to know that the 5th gear overdrive ratio is 0.79 to properly calculate RPM's in 5th gear.
Max
