My ride quality sucks, tires, lift and or shocks??? - Page 2 - JeepForum.com
post #16 of 32 Old 07-01-2013, 08:45 AM
biffgnar
biffgnar's Avatar
Originally Posted by xtreemlee View Post
According to Rancho the shocks are for 2.5 to 3.5 inch lift. I shouldn't have any issues withe the current set up or if I go with a 3" spring. I've ordered 285/75's down from 315/75,s so my ride and throttle response should be great.
Becareful relying on what lift size Rancho specs the shocks for. My experience with them is that you end up a little on the short side if you do that. Measure your actual need and then look at the collapsed and extended lengths and decide for yourself which ones are correct.
Romney in 2020!
biffgnar is offline
post #17 of 32 Old 07-03-2013, 02:24 AM
Charley3
Originally Posted by biffgnar View Post
I believe they did. You might want to stop recommending them.
Obviously I'd want to stop recommending them if they no longer make them. My LJ experience is from 06-12. I'm old and dated. However, even if no longer made, they might still have some left over and available.
Well then, let me say this, my LJ experience and advice is still vaild, if the parts are still available.
I assume the Rancho, OME, and Currie parts I recommended are still made, or at least available. I'm not going to spend my time checking on TJ parts availability when I no longer own a TJ, but I do apologize if some of my info is outdated.
The OP can check availability of the parts he wants. Good luck with the project.
Best wishes, Charley
Warning: I often edit my posts a few times to get them complete or correct errors.
Note: I had heart surgery Mar 2016. I wasn't feeling well since, but I improved this Dec 2016. Now I'm feeling better and getting back to Jeeping, modifying and wheeling.
Charley3 is offline
post #18 of 32 Old 07-03-2013, 02:36 AM
Charley3
Agreed.
However, if they're a little short for his 4" lift, the only issue I can see is lack of droop during hard articulation. A minor issue off road during hardcore wheeling. A non issue for mild wheeling. A non issue on road.
When he later switches to 2.5" or 3" springs, those Rancho shocks will (probably) be perfect length. If not perfect length, then close enough.
So no worrries, IMO.
Charley3 is offline
post #19 of 32 Old 07-03-2013, 05:26 AM Thread Starter
xtreemlee
The Rancho RS9000XL's and the Cooper Adventurer A/T3's should show up this Friday. I will keep you all posted on how it turns out.
xtreemlee is offline
post #20 of 32 Old 07-03-2013, 08:46 AM
biffgnar
biffgnar's Avatar
Originally Posted by Charley3 View Post
Agreed.
With shocks in stock mounting locations you're not really talking about "hard articulation" to have an issue. If you have 8" of travel and only end up with say 2" of droop that's going to be an issue in a lot of situations, maybe even onroad. That's the kind of issue Rancho's have if you listen to their labels. Not close enough and something to worry about, IMO.
Romney in 2020!
biffgnar is offline
post #21 of 32 Old 07-03-2013, 08:46 AM
biffgnar
biffgnar's Avatar
Had this discussion with someone else recently who did check AEV's site and he said they no longer are available for sale there.
Romney in 2020!
biffgnar is offline
post #22 of 32 Old 07-03-2013, 04:59 PM
Charley3
Cooper Adventurer AT3? I haven't heard of that tire. Did you mean Cooper Discoverer AT3?
Cooper Discoverer AT3 load C ride as soft as it gets for a relatively tough tire. I like mine. Rides almost like a passenger car tire.
Charley3 is offline
post #23 of 32 Old 07-03-2013, 04:59 PM
Charley3
OK. Good to know. Thanks.
Charley3 is offline
post #24 of 32 Old 07-03-2013, 05:02 PM
Charley3
OK. Good to know regarding his 4" springs, but he'll soon be switching to 2.5 or 3" springs. Can we agree those shocks will be good with 2.5 or 3" springs?
Charley3 is offline
post #25 of 32 Old 07-03-2013, 06:47 PM
biffgnar
biffgnar's Avatar
No, perhaps will have to agree to disagree but I think agreeing on any acceptable shock length based on a manufacturer label is punting on something that you as a consumer don't have to punt on. As another example of manufacturer's royally screwing things, look at what BDS and Fox provide as the "correct" length Fox shock for BDS 2" lift kit. Not even close. How hard is it to measure your jeep that is right in front of you and compare to published lengths that most manufacturers will provide and then buy the length that is right for you? Think for yourself.
Romney in 2020!
biffgnar is offline
post #26 of 32 Old 07-04-2013, 12:44 AM
Charley3
OK. Measure. Good idea.
Charley3 is offline
post #27 of 32 Old 07-05-2013, 04:49 AM Thread Starter
xtreemlee
yep discoverer's not adventurers, duh...
Anywho I'm having buyers remorse about downsizing from 315/75's to 285/75's there is a local discount tire I wonder if they would exchange them???
post #28 of 32 Old 07-05-2013, 03:07 PM Thread Starter
xtreemlee
How the heck do u get the new shocks to extend? They won't budge??? Help...
Answer unscrew them...
post #29 of 32 Old 07-05-2013, 06:26 PM
Gary2
It took me a bunch of combinations but my 285-75-16 Cooper STT ride good now . All said and done I ended up with 28.5 lbs in the tires . Savvy control arms with Metalcloak Duroflex bushings instead of JJs . Bilstein 5100 shocks ,3" BDS springs. I tried a number of other tires , wheels , shocks , control arm joints but it behind me know and it steers fine , next to no steering correction required . I tried an Anti-rock but the body roll had ill effects on a previous steering set up and not so sure it wouldn't have similar effects on my present. Either way I sold the AR and not interested in another .
Gary2 is offline
post #30 of 32 Old 07-05-2013, 10:07 PM Thread Starter
xtreemlee
Got the shocks installed today and did some road and offroad driving. Suc cess so far. I did not put the tires on going to go with 315/75's. I them set on the second to lightest setting. What an improvement.
