My MTR/K's are too quiet - Page 3 - JeepForum.com
post #31 of 41 Old 07-01-2013, 03:41 PM
Imped
Imped's Avatar
Originally Posted by rambo3489 View Post
Imped. Thank you. Ill run somewhere in the low 20's. But if your wrong I'll burn your house to the ground in 25,000 miles.
Deal.
Originally Posted by Maertz View Post
It could be close to 1k as just off the stock vehicle weight can be 800lbs more and if you have a winch or front bumper there's probably your other 200 lbs
Sent from my Prius
My front bumper weighs 20 lb. My winch weighs 55 lb. I don't have a back seat and my gas tank is an aluminum fuel cell. All armor is aluminum and there's about 100 lb of factory crap no longer on it. So at least in terms of sprung weight, I'm a bit lighter than stock.
Your mom weighs more than my mom.
OlllllllO
IndyORV
Imped is offline
post #32 of 41 Old 07-01-2013, 03:49 PM
Maertz
2009 JK Wrangler
Deal.
So your maybe just 7 to 8 hundred pounds more..... As for the mom thing i cant argue... Thats prolly true.. But also weird ur so pumped that your moms hotter than someone else's.... Kinky
Sent from my Prius
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #33 of 41 Old 07-01-2013, 04:18 PM Thread Starter
rambo3489
... My Mom's hot
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #34 of 41 Old 07-01-2013, 06:41 PM
rchase559
Sent from my Prius
Put your money where your mouth is then.
What is the weight of a stock YJ with a 6 cylinder and a soft top? What about a TJ with the same?
rchase559 is offline
post #35 of 41 Old 07-01-2013, 07:14 PM
Maertz
2009 JK Wrangler
http://www.jeepforum.com/forum/f96/c...2-door-509771/
Here you go.... Seen as you cant search even. As you can see it could be the case as i stated.
Sent from my Prius
Maertz is offline
post #36 of 41 Old 07-01-2013, 07:18 PM
rchase559
Cool. You can post a thread with vague numbers that tell nothing about the configurations that the weights are gathered from.
How do I know that the YJ that weighs what is listed isnt comparable to the lowest weight for the TJ?
post #37 of 41 Old 07-01-2013, 07:26 PM
Maertz
2009 JK Wrangler
We don't thats why i said could be the case.. Also id bet any numbers i would have ballparked you would have went o no you were off by 50lbs...this yj is also probably lighter than stock aswell it may not be 800 but fact is it probably weighs more... Happy?
Sent from my Prius
Maertz is offline
post #38 of 41 Old 07-01-2013, 07:52 PM
rchase559
It has a heavier front axle, thick steel armor, and heavier tires than stock. I really doubt it weighs less than stock.
You were arguing that your friends rig weighed low enough to need 40% less air pressure than other lightweight (relatively speaking) rigs. While it may weigh less I really don't feel that it's enough to make a significant difference.
We're just going in circles now though. Your friend has already gotten the help he was looking for.
post #39 of 41 Old 07-01-2013, 08:10 PM
Maertz
2009 JK Wrangler
Agreed yd u post?
Sent from my Prius
Maertz is offline
post #40 of 41 Old 07-01-2013, 08:15 PM
rchase559
Agreed yd u post?
Sent from my Prius
Who knows. It's been one of those days.
post #41 of 41 Old 07-01-2013, 08:25 PM
Maertz
2009 JK Wrangler
Ha i hear ya man
Sent from my Prius
Maertz is offline
