Mud Terrain Tires - Siped or Not - JeepForum.com
View Poll Results: WHat are your thoughts on Mud Tires
Siped only if from the Manufacturer 10 27.03%
I would have them siped myself 20 54.05%
Impartial either way 7 18.92%
Do not like or want siping 0 0%
Voters: 37. You may not vote on this poll
post #1 of 16 Old 11-08-2006, 08:19 PM Thread Starter
87Feep
1987 YJ Wrangler
I see a lot of discussion revolving around siped tires so I figured I'd start a quick poll to see what the general thoughts are about siping and Mud Type tires....
87Feep is offline
post #2 of 16 Old 11-08-2006, 10:47 PM
UCTJ
UCTJ's Avatar
I would like to have my BFGs siped but Im too cheap and lazy to take it to Discount Tire which is 1 mile away...though I have wanted to get my own tire grooving iron and do it myself. I like em siped...
UCTJ is offline
post #3 of 16 Old 11-08-2006, 10:50 PM
olds442
olds442's Avatar
wouldnt care if they were or werent, im just too lazy to do it myself
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
olds442 is offline
post #4 of 16 Old 11-08-2006, 11:45 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Cut sipes like would be done by Discount Tires is actually preferrable to molded sipes that serve for sipes in most "factory siped" tires. Molded sipes (more accurately called kerfs) are less costly, cut sipes are more labor intensive... but better for traction.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #5 of 16 Old 11-08-2006, 11:53 PM
Trouble Maker
reckless endangerer
Trouble Maker's Avatar
Before getting them siped check to see if it will void your tire warranty, at home grooving will for sure.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline
post #6 of 16 Old 11-09-2006, 04:29 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I had a set of Kumho MT's that I siped and they where great in the winter. My firestones are currently NOT siped but I may do it if I don't like the traction in the white stuff.
2013 FR-S
BlaineWasHere is offline
post #7 of 16 Old 11-10-2006, 08:00 PM Thread Starter
87Feep
1987 YJ Wrangler
Curoius to see a few more votes. SO far nobody seems to be against sipes. Has anybody had problems with the sipes ripping or getting torn up when off roading?
87Feep is offline
post #8 of 16 Old 11-11-2006, 04:48 AM
options
Getting my Goodyear MTR's done today at Discount Tire for $10 each. Ran them last winter new without sipes. With rain and snow on the way, any improved traction will be a good thing, especially for stopping! Gotta believe that a major tire chain like Discount wouldn't do it if it affected your warranty. I'll ask before they write it up and post a response later today.
'97 TJ Sport, 5 speed, 3" Pro Comp, 33" MTR's, A/R Baja's, ECGS 8.8, CenterForce, AGR Superbox 2, BDO Rocker Guards, Airaid air system, Dynomax exhaust, Cobra/Wilson, Bazooka Tube, etc...
options is offline
post #9 of 16 Old 11-11-2006, 08:22 AM
options
O.K. Had the MTR's siped this morning, took about 45 minutes. Had them rotated as they now have 3000 miles on them. $40 total, no problem with the manufacturer's tire warranty per Discount Tire.
options is offline
post #10 of 16 Old 11-13-2006, 01:46 PM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
Took my siped MT/Rs on some of the nasty sharp AZ rocks last month. It did chunk them a bit mostly due to me spinning the wheels more than I should have. The rear ones that were siped look kind of rough, the front ones (not spied) didn't look as bad. Then again the rear was locked and spinning.
Just because someone will ask, I had to replace 2 tires and the locla place wouldn't do siping. Rotate them front to rear with no issues.
Whybu1 is offline
post #11 of 16 Old 11-13-2006, 02:01 PM
Jerry Bransford
Administrator
Please tell me you only allowed them to sipe the two inner-most tread blocks, and that the outer tread blocks were left unsiped.
For strength reasons, the outside tread blocks should always remain unsiped as that is where spinning of tires on rocks etc. can cause chunking. My MT/Rs are siped but only the middle two tread blocks are... and there has been zero chunking.
Getting
post #12 of 16 Old 11-13-2006, 02:09 PM
I FLEX
I FLEX's Avatar
I live in Washington State where there is alot of rain. Im glad i got them siped. I ran them a week without and it was rough. I had to be extra cautious on turns and stops. I had the local tire shop do it for about $10 per tire and it was great. I also noticed alittle improvement on ice driving.
Its said to also help reduce tear wear by allowing the lugs to run cooler..
Check out the link, its info posted about Siping from Tire Store chain in the PNW.
http://www.lesschwab.com/siping.asp
- Micah
Muddy TJ
2001 SE 5spd | 33x12.5x15 Toyo MT's|
RE.BB with RE3.5 shocks | Anti-Rock
#13
(they are some what updated)
I FLEX is offline
post #13 of 16 Old 11-15-2006, 10:50 AM
Whybu1
Whybu1's Avatar
Yes only the inner lugs are siped. The rock here is a nasty quartz type rock. Actually able to get a nice cut off the pieces if you try. Trails run about 45 degree incline. Most damage was on the inner lugs but the outers took a little bit as well.
Whybu1 is offline
post #14 of 16 Old 11-15-2006, 11:35 AM
notch4u
huh i never seen this b4(noob to off roading in jeeps)
so how deep are the cuts, how often do you need to get it done?
most tire shops can do this?
95.5 YJ Rio Grande 2.5L.4" RE,1" BL, 33x9.5 AT's, Aussie Locker -Retired
88 Mustang Notch turbo 2.3 road race car- Street toy
02 Outback Wagon -Daily
00 Yamaha Kodiak on 27"s
notch4u is offline
post #15 of 16 Old 11-15-2006, 01:30 PM
McLovin
You only need to get it done once. The cuts pretty go as deep as the tread is tall. You just have to call around and ask if they do or not.
I have 4 new zone hydro shocks for sale...PM for a price.
McLovin is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Where can you get tires siped? ksander Tires & Wheels 9 12-14-2008 07:17 PM
siped tires Magus2727 Tires & Wheels 4 09-08-2008 08:30 PM
Siped tires cwildmann Tires & Wheels 5 11-08-2006 10:52 PM
MT/R's siped or new tires? buddastrat Tires & Wheels 4 08-09-2006 06:47 AM
If I get BFG Mud Terrain tires siped will they be better in snow/ice? svaughan Tires & Wheels 23 11-22-2004 12:31 PM
