Motor Mount Help!!!! Please - JeepForum.com
post #1 of 5 Old 12-23-2006, 01:34 PM Thread Starter
Hoff14
Hoff14's Avatar
hey
i just finish my 1inch BL and am moving on..
im installing my new 1 inch motor mount right now....but im having trouble
i loosened all the bolts and tryed jacking it up from under the oil pan but it wont work. it just jacks the whole frame up with it. its almost like the frame and motor arnt seperating.
what am i doing wrong? am i missing something?
thanks for the help!
i need to get back to work on it soon
Hoff14 is offline
post #2 of 5 Old 12-23-2006, 01:48 PM
AjRagno
Did you remove the nuts securing the rear motor mount, often referred to as the transmission mount?
http://www.4x4xplor.com/MML.html
AjRagno is offline
post #3 of 5 Old 12-23-2006, 01:51 PM Thread Starter
Hoff14
Hoff14's Avatar
yup took all 4 of those off...
its like somethings still connected or theres no room for it to move.
i just put on the 1 inch BL and now this MM is taking the whole day....
those where the instructions i was following too...
ahhhhhh i dont know what to do.......any other advice i could try?
Hoff14 is offline
post #4 of 5 Old 12-23-2006, 02:50 PM
happycamper
1986 XJ Cherokee
did the same thing last weekend 1 hr for the bl 3.5 hrs for the mm lift. I put the jack under the mtr, lifted a little then removed the bolts that go threw the mm the horizontal ones, then jacked it up, the hole jeep lifted for a moment then it finally gave, and separated. i then removed the pass side mount and installed that side but loosely then to the drivers side, had to loosen the bracket that bolts the to the motor then that side . it sounds easy but was a pain in the a$$. good luck. lol
Gone but not forgot. 2000 Sahara 4.0, auto, 4"rock krawler x factor long arm, 33x12.50x15 M.T. Mtz, M.T. classic lock rims,30/44 limited slip, land runner safari rack, land runner front, and rear bumpers, warn 8000i winch, cobra cb, jks 1.25" bl, brown dog 1" mm lift.AA sye, J.E. Reel drive shaft, Aussie locker, Rock Crusher front cover
happycamper is offline
post #5 of 5 Old 12-23-2006, 04:23 PM Thread Starter
Hoff14
Hoff14's Avatar
MANNNNN!!!!
finally got it. that thing was a pain in the as$ x10....
I just jigled it around a little jacked it up higher and it fianlly gave after a few f bombs haha
1.5 for the bl and the rest of the day worrying i was wrecking my jeep on the MM
all is well tho now!!
Tomorrow is time for the 2 BB'
thanks for the help guys......
Hoff14 is offline
Motor mount tower/motor frame mount location pepto Engines & Drivetrain 3 03-24-2009 02:07 PM
Which Motor Mount Is Better stu'sjeep Engines & Drivetrain 0 05-30-2008 02:48 PM
4 cyl. motor mount urwaker Tires & Wheels 1 04-16-2005 10:21 AM
Motor Mount Lift? TexasJeepGuy Tires & Wheels 1 07-06-2003 03:58 PM
350 motor mount for CJ-5 clegger Engines & Drivetrain 0 12-19-2001 01:32 PM
