michelim xml anybody run em? - JeepForum.com
post #1 of 5 Old 11-18-2013, 07:40 PM Thread Starter
richh789
1987 YJ Wrangler
325 85 16, 38" high. Have double the weight capacity of swampers, regrooveable, look pretty aggressive. Saw em on wartire.com
richh789 is offline
post #2 of 5 Old 11-19-2013, 01:56 PM
wilson1010
That tire was an alternative for my XM-47's on the Unimog. I think they are non DOT compliant, but I could be wrong. Of course, all Michelin military tires are fantastic. And they used to have those XML's in surplus all the time, but they were probably all 20" rims.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #3 of 5 Old 11-19-2013, 02:54 PM
KKiowaTJ
War tire or his many names, Is a scam. He takes a picture of a pile, Then says he has 200 sets and collects. Then as he can find them, You might end up with a set.
Heavy as **** to try and turn unless you have the axles and gears. Plus the fact a jeep with them, You will only need a couple pounds of air they are that thick and stiff. Mainly a mud tire for bubba and his F350 with 17" of lift and 7 shocks per front tire.
MOPAR!
KKiowaTJ is offline
post #4 of 5 Old 11-19-2013, 03:28 PM Thread Starter
richh789
1987 YJ Wrangler
I have a YJ on one ton axles, with fuel injected 360. Right now I run 39 boggers. They're just too damn expensive and don't last worth a damn
richh789 is offline
post #5 of 5 Old 11-19-2013, 04:59 PM
KKiowaTJ
In that case on ton's and FI 360, You wont be having that problem lol. He is in FL IIRC, IMO go down and pick your set if you go with them. That way you get the tire you paid for and you can also pick out the best four.
At one point he had a few locations/tire yards so one could be close. But I remember him trying to screw people on pirate4x4 a few years back. Another chuckie wenzell lol or however you spell that POS's name. Good luck either way
MOPAR!
KKiowaTJ is offline
