Metric vs. Standard tire sizes - JeepForum.com
post #1 of 3 Old 10-15-2004, 02:57 PM Thread Starter
SureThing
Some where I read a 265-75-15 is about the same thing as a 31x10.5x15. What is the metric size for a 30x9.5x15?
Also, in general, how do you figure it out?
SureThing is offline
post #2 of 3 Old 10-15-2004, 03:12 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
there are several websites that will convert for you...but, there's obviously math behind the whole thing...
you need to know two things:
1. what the "measurements" on the tires are
2. there are approximately 25.4 millimeters in an inch
knowing those two things, you can go from standard to metric and back...
31x10.50x15
31 = tire height in inches
10.50 = tread width in inches
15 = rim size in inches
265/75/R15
265 = tread width in millimeters
75 = profile ratio (width divided by the sidewall height)
to get the metric size for a 31x10.50x15:
10.50*25.4 = 266.7 (your new width in millimeters)
31 (height) - 15 (rim opening) divided by 2 = 8 (16/2) (which is your sidewall height)
8/10.50 = .76 (new sidewall ratio is 76)
so, your 31x10.50x15 is actually a 267/76/R15, which is very close to your other tire
to get the standard size for a 265/75/R15:
265/25.4 = 10.43 (your new width in inches)
265*.75 = 198.75 (sidewall height)
198.75*2/25.4 + 15 = 30.65 (your new height in inches...take the sidewall, multiply by 2 to account for top and bottom, divide to get number in inches, and add rim opening in inches)
so, your 265/75/R15 is actually a 30.7x10.43x15...also very close to your other tire...
hope that helps...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #3 of 3 Old 10-15-2004, 03:53 PM Thread Starter
SureThing
What is the Standard to Metric Conversion of a 31x10.5r15? bensmiata Tires & Wheels 8 01-15-2010 11:19 PM
Standard VS Metric Tires (305-70-16 VS 33X12.5X15) Xiled1 Tires & Wheels 13 01-23-2009 10:07 PM
Metric conversion for tire sizes Duck Dodgers Tires & Wheels 5 12-30-2007 10:50 AM
Metric to standard tires size chart renegadeyj Tires & Wheels 3 11-25-2005 09:05 AM
Help with USA tire sizes in metric. Popol Tires & Wheels 10 12-09-2003 10:45 PM
