Matching rim - JeepForum.com
post #1 of 4 Old 07-06-2013, 07:25 PM Thread Starter
tkenny11
What wheels are on my Jeep? Need a 5th
Hello everyone!
I'm new to the forum, and I'm hoping someone out there can help me!
I'm at the point where I need to buy new tires, and want to buy 5 so I can do 5 tire rotations but need to match the rims on the jeep in order to do so.
On the inside of the spokes it has these numbers:
ES-927
FA-139
16X8JJ
ET 0
MAX LOAD 1900 LBS
I know it's a 16" wheel and I'd assume that it's a 16x8.
I think the ET stands for the backspacing but I'm not positive.
Thanks in advance for any help!
tkenny11 is offline
post #2 of 4 Old 07-14-2013, 09:44 PM
nocojeep
1990 XJ Cherokee
The ES-927 and FA-139 have nothing to do with the size of the wheel, it may be part numbers or something like that from the manufacturer. The 16 x 8 is the obvious part (16 inch diamater and 8 inches wide) but the ET 0 is the offset in millimeters. A zero offset wheel that is 8 inches wide has 4.5 inches of backspacing. Backspacing or offset are both measures of where the mounting plate sits in the comparison to the front or back lip of the wheel, and there is a formula for conversion. Your bolt pattern is 5-4.5 inches or 5-114.3 mm. So those are the specs on the wheel, now just have to figure out who makes it and you can get your fifth!
nocojeep is offline
post #3 of 4 Old 09-21-2013, 10:01 AM
Gjeep2000
Wheels (I have same problem)
I recently purchased same wheels with tires installed - I cannot find anyone who knows what type wheels these are !! You have any luck? I'm trying buy a 5th as well as center caps
Glenn
Gjeep2000 is offline
post #4 of 4 Old 09-21-2013, 11:21 AM
swirve
Looks like a Les Schwab special
swirve is offline
