M.O.R.E. 1" body lift - JeepForum.com
post #1 of 2 Old 10-13-2001, 11:14 AM Thread Starter
92 RED YJ IN NJ
Does anyone have any experience with the M.O.R.E 1" body lift as shown here.
http://www.mountainoffroad.com/catal.../liftpucks.htm
I plan to purchase this for my jeep but wanted to know what others thought about the kit. Also, since this will be my first body lift, do i need the "KIT" or the "SYSTEM" thanks for the help.
Tom
1998 TJ sport, 4" rough country lift, 1.25" JKS BL, Superwinch Husky 8500, 33x12.50R15 TSL radials , 4.56's, D30 Lockright
92 RED YJ IN NJ is offline
post #2 of 2 Old 10-13-2001, 08:04 PM
jpwranglr9
i have not used them myself but i talked to someone that did. the aluminum can break in cold weather. i was gona get a set but that kinda changed my mind. Living in michigan it does get cold now and then . I also instaled a Daystar 1" body lift on new mounts and he said it is great. its about the same price as the system but it has the body lift and body mounts all in one. its kind of all up to you and how much you wheel though.
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
1.25" Body lift on top of 2" coil spacer lift? 79SilverCJ Tires & Wheels 4 01-08-2007 06:38 PM
Currie TJ 1" Body Lift vs. JKS 1.25" Body Lift MaverickTJ Tires & Wheels 7 03-10-2006 03:07 PM
2.5" sping lift w/3/4" spacer and 1" body lift... Mus35th Tires & Wheels 3 08-30-2005 08:50 PM
Does 2" OME lift + 1" Body/MM lift = No TCase Drop? Black 2001 TJ Tires & Wheels 4 10-24-2002 08:57 AM
2" Body Lift and 2" Coil Spring Lift Together a good idea?? YellowSE200 Tires & Wheels 1 01-09-2002 08:43 AM
