#1 | |
lug nuts, what the difference here
whats the difference between a bulge conical seat and standard conical seat?
1999 TJ 4.0 manual 4.88 on 35" Pro Comp Xtreme Muds/RE 4.5" lift 3.5" springs - RE mono shocks/Dana 44 locked with ARB - Alloy USA shafts/AA SYE Tom Wood's DS/AtoZ Fab Rockers/ 60" Hanson Prerunner Style Front Bumper/Jeeperman Rear Bumper Swing Away with Side Extensions/Bestop Sailcloth tinted/Roundeyes/Infinity Sound System |
#2 |
bump .
#3 |
From http://trikerdon.50megs.com/wheeladapt.htm;
2. Check and be certain the approved lug nuts are correct for the application. LUG NUTS: It is critical that the lug nut matches the thread diameter, pitch and seat, otherwise the installation will be improper, and may result in damage to your wheels and could cause a dangerous condition. The three basic types of lug nuts are: conical seat (60 degrees taper "acorn" and "bulge"), mag or shank style, and spherical or ball seat. Thread diameter refers to the diameter of the stud measured across the shank at the outer edges of the threads. Thread-pitch means either the number of threads per inch or if metric, the distance in millimeters between threads. The Seat means the area on the wheel where the lug nut will clamp down. It looks like buldge is a type of conical.
Never underestimate the power of stupid people in large groups. Last edited by bigjoe611; 05-28-2007 at 04:09 AM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
