Looking for replacement tires for quiet, soft ride. - JeepForum.com
post #1 of 6 Old 11-07-2008, 01:16 AM Thread Starter
mikedavid00
Hi!
I just got a Jeep Laredo 3.7 4x4 2008 with 12k and will do anything for a less jiggly and rough ride over uneaven road dips etc.
I'm not sure if the dealership over filled the stock tires. They claim to use nitrous oxide but the mechanic after my purchase said that he didn't think they were filled with that so I really don't know if the tire has that in it or if that could be causing harshness.
Any recommended tire (with air or nitrous) would be great. I am not after good traction, but need all season. I read reviews at TireRack and many are contradictory.
Also, I notice with my stock tires that there isn't a lot of rubber that actually hits the pavement or at least it seems that way. The tread is in 'rows' with large gaps between them. It dawned on me that they might be designed this way to up mileage. Less rubber on pavement = less rolling resistance = better milleage?
Can someoen tell me what a 'comfort tire' is and tell me the drawbacks to owning one? Thanks!
mikedavid00 is offline
post #2 of 6 Old 11-07-2008, 01:33 AM
JeepDoo
You are backwards on the mileage, the bigger the gaps between tread blocks means the worse gas mileage you will get because those gaps hit the pavement causing resistance. If you could post what tires you have right now i will give you some suggestions on what new tires to buy.
About comfort tires, they will have tread blocks running all the way around the tire without any huge breaks, that makes them quiet on the street and they get better gas mileage because they are smooth on pavement. The breaks in the tread, like you have on ur tires, are designed to grab the ground when you are on unpaved roads.
Off the top of my head, i would suggest the Goodyear Wrangler SR-A. But i could find you something better if i know what u have right now, just for comparison.
Hey hey, my my. Rock and roll will never die. - Neil Young
We've got too many gangsters doin dirty deeds. Too much corruption and crime in the street. It's time the long arm of the law put a few more in the ground. Send them all to their maker and he'll settle them down. - Toby Keith & Willie Nelson
Longboard Drunk, Jeep Naked, Ski Powder
and finish calculus homework
JeepDoo is offline
post #3 of 6 Old 11-07-2008, 05:38 AM
Macklin96
Best riding tire hands down Michelin LTX M/S. I think They meant nitrogen not nitrous. That doesn't affect your ride at all in my experience and i have installed thousands of tires at my tire shop.
Macklin96 is offline
post #4 of 6 Old 11-07-2008, 05:55 AM
Muddeprived
Muddeprived's Avatar
Check the air pressure. Should be around 30-35. Too much and the ride becomes harsh.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #5 of 6 Old 11-07-2008, 07:30 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
if tires are filled with Nitrogen, they will have a special green valve stem installed. if its just a standard black Shrader valve, then its just plain air. Nitrogen in the tires is a good idea if you drive LOTS of street mileage, and you never go off-road. Remember - air is 78% nitrogen anyway.
What brand/name and size tire is on the Jeep now? I'm guessing 245/65-17 (according to tirerack.com)
http://www.tirerack.com/tires/Compar...G&startIndex=0
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 6 Old 11-07-2008, 07:48 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
Check the previously recommended Michelins for a very comfy road ride with no off-roading. If you do light off roading then try the Goodyear Wrangler Silent Armors; my wife loves them on her WJ (better ride than the BFG ATs)
For drawback to comfort tires: the better the on road manners and mileage the smaller the tread blocks and less off road ability they tend to have. Road and off-road are at kind of opposite ends of the requirements spectrum.
Whybu1 is offline
Quiet Offroad Tires Emergency Tires & Wheels 24 08-03-2009 02:43 PM
Which are QUIET tires? PFMCDM Tires & Wheels 24 11-07-2007 09:02 PM
soft ride shocks Winters Tires & Wheels 2 11-05-2006 01:50 AM
most quiet MUD tires out there? Mac26Mac Tires & Wheels 13 09-23-2005 09:02 AM
Which tires in 33's are quiet but look good? jster171 Tires & Wheels 8 09-19-2004 03:42 PM
