Quantcast A little confused (bolt pattern and wheel width) - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > A little confused (bolt pattern and wheel width)
Old 09-14-2008, 10:41 AM   #1
LuCk3e87
ok guys im having a bit of trouble understanding this. Im getting these tires
rim tire width
size hieght size
15 33.1 33x12.50R15LT 12.50
and im looking to get cragar soft8 wheeles, now i was checking the site and it states that they come in 5.5 or 4.5 bolt on pattern... i have no clue if what is lolol. Also am i looking for the one thats 15x10? ya im not good with these things
thanks inadvance
LuCk3e87 is offline   Reply With Quote
Old 09-14-2008, 10:58 AM   #2
Mark Lange
The rim lug pattern on your Wrangler is: 5 lug- 4.5 pattern.
The tires you are buying need a 15" tall rim. You could go with a 8" wide or 10" wide rim. I like the look of 8" better. You make the call.
Rim: 15" tall, 8" wide, 5- 4.5 pattern
your tires are 33 x 12.5" wide made for a 15" tall rim.
Mark Lange is offline   Reply With Quote
Old 09-14-2008, 10:59 AM   #3
Whybu1
Go STEELERS!!!!
Whybu1's Avatar
Stick to the 15x8 it will work better for your 33x12.5s.
Whybu1 is offline   Reply With Quote
Old 09-14-2008, 11:04 AM   #4
LuCk3e87
omg u guys r life savers thanks, u kno they should have a ratign system on this site. Iv gotten so many great answers on here and it would b great to rate.
Old 09-14-2008, 01:53 PM   #5
KKiowaTJ
Many like the 15x8, But I run 15x10's and have never popped a bead and have been to 8psi before with no problems. Like said above its up to you on rim size, 15x10 will make it look wider, 15x8 they say will hold the bead better, I cant say they are wrong or right, Because i have always ran 15x10 and never had a problem. What you will wheel in/on could be a better deciding factor. Either one will work good, Just make sure you get 5x4.5 and a minimum of 4"backspacing, 3.75 is what i would go for. Good luck
Couple TJ's and a XJ
KKiowaTJ is offline   Reply With Quote
Glock Forum
