lift install question - JeepForum.com
post #1 of 3 Old 04-19-2004, 11:38 PM Thread Starter
badams
trying to get the swaybar end links off the front swaybar. top part with rubber, I got the nut off and am wondering if i should use a fork, puller or hammer to get the endlink off the swaybar? thought id ask before I damage anything.
i've got the same problem with the top stock trackbar mount, what do i use on it?
desert sand 99 tj sport, 5spd, 4.56, arb front, f8.8 rear, custom bumpers, 1"bl+mml, warn m8000, 35 12.5 trxus
badams is offline
post #2 of 3 Old 04-20-2004, 07:07 AM
Mels95YJ
Mels95YJ's Avatar
This has been covered many times, but the way I did it was a pickle fork and a BFH. The way I was told was to hit it, hit some more, keep hitting, don't stop hitting and when you don't think you can hit it anymore, hit it again. It will eventually come off. HTH
Mel
Jeep with stuff.
Mels95YJ is offline
post #3 of 3 Old 04-20-2004, 06:44 PM Thread Starter
badams
thanks for the info
badams is offline
Lift Install element981 Tires & Wheels 3 03-28-2008 11:55 AM
Mid-OME lift install question UTmike Tires & Wheels 1 06-19-2006 06:50 PM
Body lift install question, NJ nooch13 Tires & Wheels 2 08-07-2004 09:58 AM
a few ?'s before I install the ZJ lift jlr69s Tires & Wheels 4 01-22-2004 12:29 AM
How to install a 3 in TJ BDS lift Nate B. Tires & Wheels 2 08-02-2002 07:03 PM
