Lift in Front, extended shackle in back - JeepForum.com
post #1 of 2 Old 09-29-2011, 11:35 PM Thread Starter
dirtyb
1981 CJ8
I bought a CJ-8 that has extended shackles to provide lift for 32" tires. The PO really did a bad job (in my opinion) by moving from the standard 3" shackle to a 6 1/4" shackle (I think leaf springs are not stock, but I'm not sure). So it drives REALLY bad at 55 MPH or over. Unless the road is perfectly flat, it' wanders all over.
I'm looking to replace the suspension with a lift kit, but then i started to think (look out...) If you had a stock Jeep, could you buy only the front lift springs and then achieve the corresponding lift in the back with an extended shackle? This would greatly reduce the price of the lift kit, right? You could keep the stock springs in the back.
Then I thought again...Could you build some sort of "extension" bracket that would mount to the normally unchanged leaf spring perch (the part of the leaf spring where the shackle does not mount). This extension bracket would back the back of the leaf equal in height to the front of the leaf and thus eliminate the wandering at high speeds. It would be a very cheap lift using stock springs.
Has this been done?
dirtyb is offline
post #2 of 2 Old 09-30-2011, 08:24 PM
JeepXJMike20
you probley would get more responses in your model general discussions forum.
JeepXJMike20 is offline
lift , shackle , suspension
Front shackle mounts tied into frame (pics) webdr Fabrication Shop 7 07-02-2010 07:58 AM
np231 front output yoke. is ANY front/back play normal? Blk2kTj Engines & Drivetrain 1 01-25-2008 09:17 PM
Shackle/Pin size for Front Bumper BYuen General Jeep & Off-Road Equipment 5 11-25-2007 07:50 PM
Extended bumpstops & spacers in front? JT3357 Tires & Wheels 7 10-25-2006 01:57 PM
ZJ front to back lift Jeepmark Tires & Wheels 1 11-10-2004 02:40 AM
