last post regaurding tires i swear - JeepForum.com
post #1 of 14 Old 04-27-2004, 08:47 PM Thread Starter
Dr Gutiemouth
Dr Gutiemouth's Avatar
mickey thompson classic II's for 99 each...worth it? the backspacing is 3 and 5/8" and the demensions are 15 x 10
will that rim fit BFG all terrains 32" x 11.4
and will this set up stick past the stock fender flares?
please help...im thinking about buying them in two months
Green Jeep Club Member #39
The Almighty 2" BB Jeep Club Member #2
*outdated
Dr Gutiemouth is offline
post #2 of 14 Old 04-27-2004, 09:02 PM
GrimJeeper91
GrimJeeper91's Avatar
Yes, they will stick out past the fender flare. You would be better off with a 15x8 wheel for 32's (and even 33's).
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #3 of 14 Old 04-27-2004, 09:40 PM Thread Starter
Dr Gutiemouth
the 15x8 rims have a 3 and 5/16" back space to them...and a differnet wheel package deal that would be cheaper and has a 3.25" backspace to em so thats even worse right?
...looks like the classic II with 3 5/8" backspace will be my best bet... how far we talking? an inch? 1 3/16" sticking out? i might be able to get away with it right? any reason why 15 x 8 would be better? i think i read somewhere that the 15 x 10 could work too...is there drawbacks of having th wider rim?
*outdated
post #4 of 14 Old 04-27-2004, 10:09 PM
b(k)ill94xj
a wider rim will break a bead easier when aired down. The wider the rim it doesnt let the tire flex and move as much as a narrower rim. call MT and ask them about the backsapcing because i remember seeing them somewhere with 4 inchs of backspacing. maybe you have to special order the backspacing that you want and not all companies can get it.
Rocks bite hard, but trees just piss me off...
97 Wrangler sport - 2 inch RE BB - Teraflex adjustable trac bar - 3.73's d30 and d35 - 31x10.5 yokhama geolander's - 15X8 American Racing Outlaw 2 wheels 3.75 backspacing - JKS LCA skids - hella vision headlights - Alpine amp and 6.5 type S speakers
94 Cherokee Sport - 3.5 Rubicon Express Kit - RE adjustable trac bar- 31X10.5 Kumho Venture MT's - 15X8 Crager Soft 8 Class III Hidden Hitch - Hand Throttle - High flow cat w/ Delta Flow 40 muffler Transfer Case Skid Plate Removable Doors --SOLD :( :( i miss it so much
b(k)ill94xj is offline
post #5 of 14 Old 04-28-2004, 07:56 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
Yeah its sucks when you blow a bead, huh Bill
I have 15X10 and I wish I bought 15X8. Actaully now that I', getting close to what I've wanted it worked out for the better, I want 12.50 or 13.50 wide tires next. But for you, I'd say get a 15X8 with 4-4.5' BS.
BTW, get the mud tires
Matt
MSHarnett is offline
post #6 of 14 Old 04-28-2004, 09:14 AM Thread Starter
Dr Gutiemouth
yeah i havent found MT with 4 or 4.5 backspacing...i guess im gonna lose an arm and leg for these things if i get em special huh? any sudjestions where i can find rims that have the backspacing and are 15 x 8, and maybe have tires too? like a package deal?
*outdated
post #7 of 14 Old 04-28-2004, 09:21 AM Thread Starter
Dr Gutiemouth
yeah i just called them...they dont special order rims...just what tehy advertise is what they make
*outdated
post #8 of 14 Old 04-28-2004, 09:24 AM Thread Starter
Dr Gutiemouth
oh wait they sell em at 16" im a dumb as$
16X8 5-4 1/2" 4" 3100 LB
*outdated
post #9 of 14 Old 04-28-2004, 11:14 AM Thread Starter
Dr Gutiemouth
am i gonna have trouble finding 32" to fit 16x8 MT classic II???
*outdated
post #10 of 14 Old 04-28-2004, 11:19 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
You can find 32" tires with a 16" rim, but they always cost more. Your best bet would be to find a diffrent rim that you like. Here is where I bought mine from.
http://www.wheelsforless.com/
Matt
post #11 of 14 Old 04-28-2004, 11:36 AM
b(k)ill94xj
yea i knew isaw them somewhere with that backspacing, you could alwasy get american racing rism, they have a rim simalr to the MTII there is also a compny called ultra wheels i think, (made my procomp) that has a wheel similar to the MTII.
post #12 of 14 Old 04-28-2004, 03:59 PM Thread Starter
Dr Gutiemouth
i cant find 15x8 rims anywhere that has 4 or 4.5 backspacing.. it just int happening...i find 16x8 rims with the backspacing...but no tires to go along with it ..
any ideas?
*outdated
post #13 of 14 Old 04-29-2004, 01:43 PM Thread Starter
Dr Gutiemouth
any ideas? i need some wheels to go with my lift pretty soon.....will 33" fit on a BB without rubbing? or do i need a BL with that?
*outdated
post #14 of 14 Old 04-29-2004, 04:24 PM Thread Starter
Dr Gutiemouth
ok...i think im gonna run 33" bfg a/t tires one 15x10 mickey thompson rims...they'll stick out a bit im guessiing but i'll live...some of the rides down here in cbus cant be street legal...tall trucks...low rider trucks whose wheels are out 3 feet and so on....and then im gonna add a 1" BL is this a good set up? is it hard to do?
also
im thinking about buying from desertrat anyone do buisness with them? they got good prices...is there stuff used? i know they have one section where its used stuff....could someone please answer my questions? im kinda lost....
summary:
is desertrat a good place to buy a mickey thompson 15x10 classic II mounted and balanced on bfg a/t 33" tires?
and is a good idea ro have this set up on a 2" BB...
...should i add a 1" BL to the mix or should i wait?
is a bl and lift combo hard to instal correctly? will i need to cut stuff and re mount things or get vibes?
*outdated
Tires & Wheels (Wheel width for 12.50 wide tires) cowboy1107 Tires & Wheels 16 12-21-2011 07:19 PM
questions regaurding broken motor mount 4wheeler4LIFE Engines & Drivetrain 1 07-09-2009 07:08 AM
Recommend AT tires to replace factory tires on JK. RafaelSmith Tires & Wheels 2 04-01-2009 05:32 PM
AT/MT Hybrid Tires - The best daily driver tires for weekend warriors, IMO. CB3 Tires & Wheels 54 01-25-2008 05:47 PM
