Largest tire size on stock suspension - JeepForum.com
post #1 of 14 Old 04-04-2014, 09:36 AM Thread Starter
Limecuda
2011 JK Wrangler
Hello All, just picked up a 2011 wrangler unlimited rubicon and will need tires soon. What is the largest I can go with the stock suspension (with new rims of course) 31", 33", or 35"? Right now I have 255/75/17. Thanks
Limecuda is offline
post #2 of 14 Old 04-10-2014, 12:55 PM
Charley3
I've heard stock JK can fit 33s, but I'm not a JK expert.
Isn't the size you have a 32 or 33?
Sounds like you already have a good size tire.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #3 of 14 Old 04-11-2014, 04:58 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Then you shouldn't be giving advice on something you are not knowledgeable on.
A blanket statement like that is simply not true. Not all 33s are created equal. Some run short, those might fit depending on wheel backspacing. Key word, MIGHT. My Pro Comp 285s rubbed on every day street driving, and those are "33"s and not known to run big.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #4 of 14 Old 04-11-2014, 08:26 PM
222Doc
222Doc's Avatar
i have seen 33x12.5"s rub on 2" lifts. in a flex at lock. The stock are about 32. more like 31.5 RL. with front in disconnect, in flex, wheels turned to lock they are about at the top.
read the "will it rub" Sticky.
222Doc is offline
post #5 of 14 Old 04-12-2014, 12:12 AM
Charley3
I qualified my statement accordingly.
Charley3 is offline
post #6 of 14 Old 04-13-2014, 07:32 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Then why comment at all if you don't know what you are talking about? This leads to confusion caused by the "I read on the net....". Do you feel it's better to give bad advice than no advice at all?
Sorry OP. I just hate it when people try to give advice when it's clear they don't know what they are talking about, regardless of any caveats they may throw out there. IMHO, this leads to confusion for new Jeepers when they read the over abundance of info available on forums such as these.
post #7 of 14 Old 04-13-2014, 08:14 PM
Charley3
The OP posted the OP on 4/4/14. No one commented or helped him for 6 days. Where was your helpful presence for 6 days? On 4/10/14 I tried to be helpful to him because no one else was helping him. I qualified my comments.
Up till I posted, everyone had been ignoring the OP for a week.
You didn't take any interest in his thread until after I posted in it. Soon after I posted here, then you showed up. Why is that? Are you my own personal stalker troll?
You think you know everything about every model of Jeep and every terrain and climate.
You aren't smart enough to realize that the guy in the psi for sand thread posted at the end of thread that he had used 15 psi with great results, which was a lot closer to the psi I recommended than what you recommended. He used what was right for his 31 tire size at that beach. I was far closer to correct psi than you were. And that's when you started stalking and harassing me across multiple threads.
That's why you came to this thread. You had no interest in this thread until after I posted here.
Middle finger.
P.S. - the excessive, childish, obnoxious use of emoticons to insult and mock is normally your thing, but a taste of your own medicine is good for you.
Charley3 is offline
post #8 of 14 Old 04-14-2014, 07:08 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Middle finger.
LOL, don't flatter yourself. I don't see every single thread and post every day. I just have to call BS see I see it. I also don't feel I know everything about every Jeep. That's why I don't post or give advice on XJs, Cherokees.... I stay out of areas I don't have experience in and suggest you do the same.
Please try to stay on topic. Bringing in other topics does nothing for this thread or the OP. Sorry you feel the need to resort to personal attacks. This behavior does nothing for the OP but when you repeat yourself multiple times to try to push your point, even when you lack the knowledge on that topic, BS needs to be called so the OP does not follow that erroneous advice.
Sorry OP that someone had to hijack your thread and turn it into a personal attack thread.
post #9 of 14 Old 04-14-2014, 07:26 AM
WXman
Stock suspension you can do 33x12.50-15 or if you want bigger wheels try 285/70-17. That's the max with proper offset wheels.
On stock wheels, 255/80-17 is max size.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #10 of 14 Old 04-15-2014, 09:03 PM
Charley3
Interesting. I don't recall the OP saying whether he meant stock wheels or aftermarket wheels. I had assumed he meant aftermarket wheels. Perhaps some other people assumed he meant stock wheels. Perhaps that is one of the root causes of the earlier dispute, along with a certain person who is predisposed to making personal atracks and always looking for an excuse to do so.
Wxman, I find your post wise and informative. Hopefully so will the OP.
Charley3 is offline
post #11 of 14 Old 04-15-2014, 09:09 PM
Charley3
OP, I think Wxman addressed your question well, especially since he discussed wheels as part of the topic.
Charley3 is offline
post #12 of 14 Old 04-16-2014, 04:46 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Since you stated in your OP 33" tire with aftermarket rims it would be safe to say that combination will rub as that is essentially the same as stock wheels with spacers and it has been stated here before that combo will rub. You can see that from the C&P below. You would either have to run flat flares or a lift to be able to run 33s with no rubbing, given proper wheel offset as well.
http://www.jeepforum.com/forum/f96/faq-will-rub-610856/
FAQ: Will it rub?
The JK with stock wheels, no spacer, no lift
32" tires: no rubbing
33" tires: some rubbing
35" tires: don't try
The JK with stock wheels, 1 1/4" wheel spacer, no lift
The JK with stock wheels, 1 1/2" wheel spacer, no lift, Bushwacker flat-top flares
33" tires: no rubbing
35" tires: rubbing that can be cured with trimming pinch-seam
37" tires: don't try
The JK with stock wheels, 1 1/4" wheel spacer, 2" lift
35" tires: some rubbing
The JK with stock wheels, 1 1/4" wheel spacer, 4" lift
35" tires: no rubbing
37" tires: some rubbing
38" tires: be careful
39" tires: don't try
What kinds of wheels can I run on my JK?
Of course, any stock wheel that comes with the JK will be able to be used. If you are looking through the junk-yard and you find some rims that you really like, make sure that they are a 5-bolt pattern on 5" diameter. Chevy 1/2-ton pick-up trucks in the 2wd variety use this bolt-pattern.
You will be able to fit some 15" rims and all 16" and bigger rims on your Jeep. The only problem that you might run into is the brake-caliper rubbing on the inside of the 15" rim, depending on off-set. If you find the rims you choose rub - a set of wheel-spacers can be installed to move the rim further from the caliper.
Check the tire-manufacturer's recommended rim-width prior to running the tires on the rims that you choose yourself.
So, as I stated before, it will rub and I have provided you the back up so you know this is not pure speculation from someone who doesn't know what they are talking about.
Hope this helps. Sorry about the pissing contest, as I stated before, I have to call BS when I see bad advice being given out.
Pic is of my 08, stock wheels, 2" BB in Moab a few years ago.
FWIW, I once followed the advice of a self proclaimed experts on the Internet and was disappointed with the result. Just trying to help so you don't make the same mistake by taking the advice of someone who already verified he doesn't know what he is talking about and just wants to be argumentative on a subject he is not knowledgable on.
BTW, post up pics when your Jeep gets her new shoes. Jeep porn is always appreciated.
post #13 of 14 Old 04-17-2014, 06:40 AM
HappyTrails
HappyTrails's Avatar
Ok, guys...
I have ridden with guys in JK's that are running 33/12.5's on no lift. They do not rub if given proper offset wheels. You will need a wheel with 4.5" of backspacing or less.
You can fit 35's on a JK with no lift (and 4.5" offset wheels). Wouldn't take it off-road, though.
Most JK's run 2.5" of lift for 35's and 4.5" backspaced wheels. No wheel spacers.
I am running 37's on 2.5" of lift, 4.5" backspaced wheels, 1.5" spacers, and flat fenders. No rubbing.
That chart quoted above is all based on STOCK wheels with 6.75" offset. Get some wheels with 4.5" offset or less, and you can fit some very large tires with little/no rubbing on the lower control arms.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #14 of 14 Old 04-17-2014, 08:36 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Originally Posted by HappyTrails View Post
Ok, guys...
Your first statement is not entirely true. It's a your mileage may vary sort of statement. The 4.5" I have no experience with but can tell you 4" BS rubs, 3.75" BS rubs. When you start sticking the tires out farther with less backspace, you aren't running on the inside, you are rubbing on the outside. The flares. It's that off camber stuff, wheels turned, tire jammed up in the wheel well but it still rubs.
Keep in mind, given enough time and effort/money, you'll be surprised what you can make work. Remember Lower 40? Running 40s on a stock height JK! For the most part though, with the exception of one small area (4.5" BS), 33x12.50s will rub on a stock JK.
