Keep traction while muddin - JeepForum.com
post #1 of 21 Old 01-22-2005, 12:41 AM Thread Starter
or8008
So I went muddin last week and the whole time I had extreme amounts of mud sticking to my tires. So much mud in fact that the tire was just as good being bald. The mud made the tread completely slick and flat. I saw other rigs, some also with ATs, going in the same places I was going yet not as much mud as I had on the tires. I did spin the tires every once in a while to get the mud off but it didn't quite help when i was actually in the mud. I know mud WILL stick to the tires, obviously, but how can I reduce the amount of it on my tires and actually have decent traction while im in the mud?
Thanks
1998 Sahara TJ 4.0 5spd
RE 3.5 SF f/r trackbar - 32x11.5 BFG AT - DANA 30/44 4.11 - CURRIE sye/custom DS - OX locker rear - XRC8 winch gen 2 (free!) - OR-FAB tire/gerry can carrier - Yaesu/Kenwood vhf/uhf
or8008 is offline
post #2 of 21 Old 01-22-2005, 02:08 AM
87warrior
87warrior's Avatar
From what little mud running I have done, you just have to hammer down on the skinney pedel I suggest avoiding it in general and sticking to the rocks, but hey thats just me
03
(Rubicon build)
92
(92/99 Comanche Project)
86
(Heavy Four)
87warrior is offline
post #3 of 21 Old 01-22-2005, 03:51 AM
TXST8tj
TXST8tj's Avatar
get a mud terrain tire
Patrick
TXST8tj is offline
post #4 of 21 Old 01-22-2005, 03:56 AM
TXST8tj
TXST8tj's Avatar
but seriously though....all terrain tires aren't meant to be fantastic in mud. they are a general purpose/general terrain tire. they are made to do acceptable in each type of terrain. now the BFG AT is a great tire..all around..but don't expect to be able to mud bog with them.
you may now think, ok, please actually answer my question on how to reduce the amount of mud sticking to the tires so you can get better traction......
solution #1) stay out of heavy mud
solution #2) get a mud terrain tire
Patrick
TXST8tj is offline
post #5 of 21 Old 01-22-2005, 04:08 AM
olllllllo.us
x2 Keep 'em spinnin' through the mud.
Remember: Mud=$$$$$
*Amanda*
olllllllo.us is offline
post #6 of 21 Old 01-22-2005, 05:49 AM
VTMurphy
VTMurphy's Avatar
Gotta keep 'em spinning so that they are constantly clearing out . Momentum is also your friend when entering a mud pit so I would say to enter at a fair speed ( 2nd or 3rd gear ) and don't let off the skinny pedal until you are out the other side . Other than that you could try spraying your tires with non-stick cooking spray before mudding but not sure if that would work .
But honestly , you'ld be doing yourself a huge favor by getting some mud tires if you're going to be doing alot of that kind of wheeling .
2004 Silver Rubicon (his)
2005 Black Rubicon (hers)
They have those " Trail Rated " badges so they don't need anything else , right ?
VTMurphy is offline
post #7 of 21 Old 01-22-2005, 06:20 AM
yogi
yogi's Avatar
thats a good way to push your fan right through your radiator seen it done not a pretty site
yogi
COME TO YOGI & SUES 7TH ANNUAL PIG GIG AUGUST 14TH -16TH AT ROCK AND VALLEYS ORV PARK2001 xj
yogi is offline
post #8 of 21 Old 01-22-2005, 07:02 AM
jruba
I heard Pam spray works ok , i havent tried it yet, so im not sure ....but if you do a lot a mud , get some super swamper's
jruba is offline
post #9 of 21 Old 01-22-2005, 07:33 AM
under_psi
silicone, armor all, wd-40, pan coating....all work great on the flares and undercarriage, but not on the tires too much.
basically a tight tread pattern is going to hold on to the mud more and it depends on the overall tread pattern of the tire as to how it will self clean...
if you want to go be billy johnson in the mud, buy yourself a set of super swamper TSL radials or some boggers....then you will be set....i have the thornbirds, and although they are technically an AT tire, they perform well in the mud....on a final note....here in mississippi the mud holes here along the trails are basically like CLAY, and even boggers can get slicked over, i have seen it, what i am trying to say is that even the best MT tire can still get slicked over.....
What's coming through is alive. What's holding up is a mirror. But what's singing songs is a snake looking to turn this piss to wine. They're both totally void of hate, but killing me just the same. The snake behind me hisses what my damage could have been. My blood before me begs meopen up my heart again. And I feel this coming over like a storm again. considerately. Venomous voice, tempts me, drains me, bleeds me, leaves me cracked and empty. Drags me down like some sweet gravity.
under_psi is offline
post #10 of 21 Old 01-22-2005, 07:33 AM
Snowman01TJ
Pam on the tires is a good thing!
Blue Jeep Club Member #30
Hurricane Jeep Club Member #3
2001 Wrangler Sport 4.0L
Teraflex 3T
Mickey Thompson Classic II
BFG AT KO 33X12.50
Snowman01TJ is offline
post #11 of 21 Old 01-22-2005, 07:36 AM
VTMurphy
VTMurphy's Avatar
yogi
Now that I got a few cups of coffee in me 3rd gear does seem a little excessive . I guess hitting mud doing 40mph with the pedal to the floor might be a bad idea !
What I was trying to say was that you don't want to pause in the middle to shift into another gear or 4WD because once you lose momentum you will have a very hard time getting moving again . More of a "steady" speed concept .
VTMurphy is offline
post #12 of 21 Old 01-22-2005, 10:55 AM
olllllllo.us
you don't want to pause in the middle to shift into another gear or 4WD because once you lose momentum you will have a very hard time getting moving again . .
.....and, if you have a manual and shift while your in some mud, you could suck mud up into the clutch. Ask me how I know.
*Amanda*
post #13 of 21 Old 01-22-2005, 11:32 AM
AudioGuru
AudioGuru's Avatar
Airing down will help, too. This allows the tire to grow more when spinning due to centrifugal force. This opens up the voids and helps spit the mud out of the gaps.
Don't lie. God said so.
AudioGuru is offline
post #14 of 21 Old 01-22-2005, 04:41 PM Thread Starter
or8008
All right very helpful. Ill try the cooking spray and see how it is.
Thanks
or8008 is offline
post #15 of 21 Old 01-25-2005, 11:31 AM
jeep32mudtaman
Have you tried to put chains on your tires. Chains will give you more traction in the mud or snow. If you are just muddin look into a set of chains for alot cheaper than buying a whole new set of tires. If you rock crawl and mud in the same trip look into some super swamper boggers. Great preformance in mud and in the rocks.
jeep32mudtaman is offline
Getting traction DirtyJeepBoy General Jeep & Off-Road Equipment 5 11-14-2009 02:45 AM
traction bar kasbiker38 Fabrication Shop 2 06-22-2009 04:58 PM
Best Wet Traction MT? NavinRJohnson Tires & Wheels 22 10-28-2006 01:01 PM
SOA Traction bar 5.0YJ Engines & Drivetrain 5 08-31-2006 08:35 AM
muddin 94 sweet sahara General Jeep & Off-Road Equipment 43 01-19-2004 04:44 PM
