Jeep TJ Vibration - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Jeep TJ Vibration
ZONE 4.25" combo lift for TJ available at Rockridge4wNew Hours at RUFFSTUFF!Enjoy 5% off in April 2000-2006 Jeep Wrangler Ignition Coi
Unread 03-16-2011, 10:40 PM   #1
skullvalle
Jeep TJ Vibration
I just bought a 2004 Jeep TJ to replace my YJ. I seem to have a vibration under load. Mostly from 40mph to 70mph. It is noticible on the freeway the most when it is in overdrive (auto trans) going up a slight hill. I have replaced the U joints, Trans mount, and put cam bolts in to adjust the Axle so the drive shaft angle is correct. The shop is telling me that it is the tires I have on the jeep. The tires are ProComp Mud Terrain 33 x 12.50. Does that sound correct to anyone? If I am driving on the highway and I go over a bump the noise changes if the back end of the jeep is going up and down as well. Looking for help, Thanks
skullvalle is offline   Reply With Quote Quick reply to this message
Unread 03-17-2011, 12:28 AM   #2
sbrendan420
Could be your tires rubbing?
sbrendan420 is offline   Reply With Quote Quick reply to this message
Unread 03-17-2011, 12:48 PM   #3
Coinpurse
I know the 2004's had a recall for a rear axle problem. Could be that... If you lived in Louisiana, I'd blame the roads.
Coinpurse is offline   Reply With Quote Quick reply to this message
Unread 03-17-2011, 09:28 PM   #4
skullvalle
I put on the 7 inch fender flairs already so they cover the tires perfectly. The The noise is a constanct noise so it is not the tires bottoming out or rubbing. 4wheelsParts people are telling me me it is the aggressive tread design on the tires. I don't know what it sounded like with other tires since the tires were on there when i bought it. Still not sure, only thing left is the pinion bearing, carrier bearings and or axle bearings unless anyone else has a suggestion.
Unread 02-08-2013, 07:02 PM   #5
jleslie246
I know this is an old topic but hopefully you found the problem. I think I have the same one. My tires are 33" BFG AT's. 4" lift, SYE etc (in my profile). I tried swapping drive shafts, moving adjustable upper rear control arms in and out. The vibration is felt in the tub, seat, center console. I do not feel it coming through the shifting lever (mine also Auto Trans). Was gonna try trans mount next.
Any tips?
jleslie246 is offline   Reply With Quote Quick reply to this message
Unread 02-12-2013, 08:05 PM   #6
numchuck
pirate squirrel
numchuck's Avatar
does the vibe go away or change if you turn off the overdrive ?
- Chuck - Nth Degree 4.5" short arm the "Dude" abides
numchuck is offline   Reply With Quote Quick reply to this message
Unread 03-11-2013, 05:53 AM   #7
jleslie246
I dont see many people posting what "fixed" their vibe problems. So here is what fixed mine. After doing the transmission mount (it helped a little, and mine was worn out) I took a closer look at my driveline angle. I adjusted the axle/pinion to be inline with the drive shaft (pointing directly at the DC joint) and the vibration is now 99% gone. I can live with this. I will check it with an angle finder soon and adjust as needed. Good luck.
Unread 03-09-2015, 08:57 AM   #8
Camdino225
This is to jleslie and OP, while I have not personally felt the ride of either of your tires but I can't imagine that your vibes are coming from the tires... If that was the case you wouldn't have a vibration at all, you would have a distinct hum, or drone sound. The only tires I would think would give you an actual vibration are boggers or similar tires.
Camdino225 is offline   Reply With Quote Quick reply to this message
Unread 03-11-2015, 10:58 PM   #9
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Vibrations from aggressive tires are only felt at slower speeds.
Even Boggers roll smooth once you hit 20-25 MPH or so.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
