Internal Beadlocks - JeepForum.com
post #1 of 7 Old 12-02-2010, 02:09 PM Thread Starter
TJnProgress
Internal Beadlocks
I'm due for tires and have been looking at options with respect to the spare.
One of the options is the Staun Internal Beadlock.
- At just north of $600 for a set of 4, they are more expensive than a spare tire. But if you consider the cost of that 35" spare, the upgraded spare mount, and associated bumper, they aren't too bad.
- Then add in the 5-year warranty, the thought that they will last through a few sets of tires, and the reduced weight/space requirement.
- From what I've read, I could air down lower, and still maintain a better beadlock, because of the 50psi holding the bead in place but without true beadlocks (illegal for road use in CA).
- I kinda prefer not having the spare hanging off the back of my Jeep and really liked the increased visibility out the back, but we all know what putting the spare in the tub does for your packing space.
I did a search and found several references to the Staun product as a recommendation, but none from anyone that had seen them in action or used them on the trail.
What I'm interested in, is actual experience using them, but would also like to hear thoughts and opinions. Don't worry, I'm flame retarded, I mean retardant.
TJnProgress is offline
post #2 of 7 Old 12-02-2010, 02:13 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Sorry, I don't have any experience with Staun beadlocks so I cannot offer any feedback.
I just wanted to suggest that you also look at an alternative that is made by Inner Air Lock:
InnerAirLock, LLC - BeadLocks
Wheelin98TJ is offline
post #3 of 7 Old 12-02-2010, 02:14 PM
biffgnar
biffgnar's Avatar
Check Noturmailman's build thread. IIRC he's not thrilled and planning on getting rid his.
biffgnar is offline
post #4 of 7 Old 12-02-2010, 02:14 PM
DH19922010
http://www.jeepforum.com/forum/f9/st...wobble-887513/
I used to be interested in them but they sound like too much of a pain.
DH19922010 is offline
post #5 of 7 Old 12-02-2010, 02:17 PM
biffgnar
biffgnar's Avatar
Actually this was the noturmailman's thread I was thinking about, not his build thread. Sorry.
biffgnar is offline
post #6 of 7 Old 12-02-2010, 04:40 PM Thread Starter
TJnProgress
Wow! Very helpful link, thank you. Back to the drawing board...
post #7 of 7 Old 12-02-2010, 06:12 PM
CJ8Ted
1985 CJ8
Sounds like you are thinking of not having a spare at all? If this is so, I just wanted to make the comment of what I have seen. I have seen more tires that were ruined (sliced, pinched, hole, ect.) that could not make it home and had to use a spare, then ones that had blown a bead. Most blown beads can be cleaned and reseated in a short amount of time. Spares are needed in my opinion, even if it is a non matching trail spare being close to the same size.
Ted
1985 CJ8 on 33s W/ 4.56s
CJ8Ted is offline
89 internal slave jacobAnstett YJ Wrangler Technical Forum 2 09-15-2010 04:27 PM
JK internal compass... Vertisce JK Wrangler Technical Forum 5 05-16-2009 01:55 PM
Internal slave pin merlin7782 YJ Wrangler Technical Forum 2 12-04-2007 06:07 PM
NP 231 Internal Noise JPH YJ Wrangler Technical Forum 6 07-25-2005 05:17 AM
internal ARB leak robndeb TJ Wrangler Technical Forum 10 02-26-2005 09:17 PM
