inexpensive 5x4.5 alloy wheels? - JeepForum.com
post #1 of 5 Old 03-29-2011, 05:00 AM Thread Starter
melk
I'm running factory r15 canyons on my ZJ (5" bs) and am looking to jump from 30s to 33x12.5 (I'm fully cut front and rear, and I'll have proper lift and everything squared away first) but I will need wheels with less BS.
Tight budget so I'm looking for an alloy wheel that is $100 or less each. Soft 8s are cheap but heavy. I'm trying to help the 4.0 as much as I can and avoid steel wheels.
The other option I suppose is to just run spacers, but it's nearly as expensive as buying a set of cheap wheels. Any suggestions on inexpensive alloy wheels? Thanks!
melk is offline
post #2 of 5 Old 03-29-2011, 05:54 AM
CrawlingForward
I was recently looking as well, and there really isn't such a thing as a cheap aftermarket alloy wheel. I ended up ebaying OEM alloy wheels off a Cherokee (I was looking for 16s)
Find a vehicle that comes with wheels that would work and eBay them. Might be hard to find the correct backspacing, but with a little research, you should be able to find one.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #3 of 5 Old 03-29-2011, 06:02 AM
Dirty Backroads
Dirty Backroads's Avatar
There are lots of alloy wheel for $100 or less. No need to go with heavy steel wheels that are hard to balance.
Try this place: http://4wheelonline.com/TruckWheels.1180
The Ion wheels have free shipping and some 15x8 wheels are under $80 PLUS free shipping! I paid $96/wheel for my Pro Comp 7069s. Had to pay shipping though.
Here's the thread about the Ions..
http://www.jeepforum.com/forum/f15/ion-wheels-1139043/
2005 Solar Yellow TJ Sport
Yellow Jeep Club Member #123
Originally Posted by Sniper111
Nothing like going topless with some Kid Rock blasting looking down on the rice boys with their dropped Civics wondering what Japanese steel would look like under the Mickey Thompsons.
Dirty Backroads is offline
post #4 of 5 Old 03-29-2011, 06:10 AM
CrawlingForward
I stand corrected. Awesome! I was not able to find any I liked in 16s. (Especially not in the 16x7 that I needed for the tire size I'm looking to run)
post #5 of 5 Old 03-29-2011, 10:01 AM
cvd
cvd's Avatar
Some Costco's carry ProComp alloy wheels, worth looking at. If you are going with larger than stock tires, you probably will have to buy the wheels from Costco and take them elsewhere for tires.
cvd is offline
Looking for inexpensive black steel wheels for '07 JK Grimscale Tires & Wheels 3 06-21-2008 10:25 AM
AEV Alloy Wheels sdlemaster Tires & Wheels 9 05-25-2007 08:01 PM
Wheels: Steel vs. Alloy nat441 Tires & Wheels 11 05-18-2007 01:37 PM
Need recommendation for inexpensive 15" wheels wwhitby Tires & Wheels 4 10-02-2005 10:47 PM
ION Alloy Wheels gdugas Tires & Wheels 2 07-31-2005 09:04 PM
