If i bed line my rims will it throw off the balance - JeepForum.com
post #1 of 37 Old 07-12-2010, 12:07 AM Thread Starter
jhf56
I am going to paint my rims, and i reall like the way duplicolor spray on bedliner looks on rims, but i was wondering if it would throw them off balance. Any advice?
jhf56 is offline
post #2 of 37 Old 07-12-2010, 12:18 AM
moonshinefuel
If its all sprayed evenly, the balance should be the same.
moonshinefuel is offline
post #3 of 37 Old 07-12-2010, 01:05 AM
2006_Sport
It most likely will and unless you run dynabeads they are gonna be a ***** to balance with traditional weights. Bedlining wheels is probably something you should skip.
2006_Sport is offline
post #4 of 37 Old 07-12-2010, 01:49 AM
AlexGeorgakis
Ever thought of how tough it's going to be to clean those rims?
AlexGeorgakis is offline
post #5 of 37 Old 07-12-2010, 05:58 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i bet its going to be nearly impossible to balance. you're adding a lot of weight for no reason. don't do it.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 37 Old 07-12-2010, 06:06 AM
MikeUnlimited04
that spray on bedliner weighs nothing. I dont think it would be an issue unless you're COATING it.
United States Air Force F-15E Strike Eagle Crew Chief
Silver JEEP Club Member #36
MikeUnlimited04 is offline
post #7 of 37 Old 07-12-2010, 06:54 AM
JBTJ
A friend of mine did his. Said it was the WORST thing he ever did to the JEEP. He sanded the rims down so it would stick to the bare metal. It did for about a year then started to flake off. Now some of it won't even come off, looks like crap. He went out and bought new rims
JBTJ is offline
post #8 of 37 Old 07-12-2010, 07:40 AM Thread Starter
jhf56
ok does anybody recommend a paint that i should use. I either want to go black or gun metal gray, i feel that will go well with the color of my jeep.
jhf56 is offline
post #9 of 37 Old 07-12-2010, 08:10 AM
happymudder10
Powder coat
Just a traveling cat in a tall black hat riding a goat. Nothing to see here.
happymudder10 is offline
post #10 of 37 Old 07-12-2010, 08:14 AM
Comanche717
1989 MJ Comanche
Originally Posted by happymudder10 View Post
powder coat
ding ding ding!
89 MJ 4.0- Ax15, D30/D44, Getting a SOA and RC 4.5 stuff up front, 33/12.5s, Flowmaster Super 44 :)
Need a set of 15x8 rims please!
I've had and rode in Jeeps with all types of lifts and none of them rode like a car! It's a freaking Jeep.Love it or leave it.
Comanche717 is offline
post #11 of 37 Old 07-12-2010, 08:20 AM
Dryseals
1980 CJ7
Are they steel or aluminum?
Dryseals is online now
post #12 of 37 Old 07-12-2010, 12:47 PM Thread Starter
jhf56
aluminum
jhf56 is offline
post #13 of 37 Old 07-12-2010, 01:58 PM
jforse
Bad idea. They wont balance out and you adding un-needed unsprung weight. Do paint or powdercoat or anodizing.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #14 of 37 Old 07-12-2010, 02:30 PM
freeskier93
I don't suggest doing this, but to say it's going to add unsprung weight is a bit ridiculous. Your only looking At maybe 3-4 ounces a wheel , at the most.
freeskier93 is offline
post #15 of 37 Old 07-12-2010, 02:32 PM
Unlimited04
Originally Posted by freeskier93 View Post
Your only looking At maybe 16 ounces a wheel , at the most.
and wheels are balanced within 0.25 oz or less typically...if the thickness isn't perfectly even you'll never get the wheels to balance right.
Useful Write-Ups:
Funny:
rims , wheels , paint , bedline , line , liner , balance
Driveshaft - to balance or not to balance??? brtt485 YJ Wrangler Technical Forum 7 09-08-2009 05:32 PM
toe in, balance, alignment help joemomma4040 TJ Wrangler Technical Forum 3 06-14-2008 11:45 AM
Out Of Balance mdot TJ Wrangler Technical Forum 6 07-10-2006 04:20 PM
Balance MCanavan TJ Wrangler Technical Forum 22 05-21-2006 10:55 PM
Out of Balance EricS TJ Wrangler Technical Forum 10 09-25-2003 06:01 PM
