I Want to Keep My 31's!!! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > I Want to Keep My 31's!!!
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-01-2004, 03:16 PM   #1
rockon1202
I've got 31" by 10" or 10.5" tires on my otherwise stock 98 TJ. Problem is that when I've got the steering wheel cranked all the way left or right, I get a decent amount of wheel rub. Is there any way to fix this without going down a size? I can't afford a lift, so I was wondering if there was some other way to fix the problem until later, without switching tires...
rockon1202 is offline   Reply With Quote Quick reply to this message
Unread 05-01-2004, 03:40 PM   #2
river rat
Forum porn star...I guess
river rat's Avatar
This will do the trick. http://www.stu-offroad.com/misc/steerstop-1.htm
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline   Reply With Quote Quick reply to this message
Unread 05-02-2004, 01:40 PM   #3
MSHarnett
Broke Bogger
MSHarnett's Avatar
Where exactly is it rubbing, if you don't want to adjust the steering stops (loss of turning radius) then maybe you could trim away what ever is rubbing.
Matt
MSHarnett is offline   Reply With Quote Quick reply to this message
Unread 05-02-2004, 03:40 PM   #4
river rat
river rat's Avatar
I'm sure it's rubbing on the LCA's. I don't think he wants to be trimming on those. All you should have to do is add like one washer and that should take care of it. You won't even notice the loss in radius. Troy.
