I Want to Keep My 31's!!! - JeepForum.com
post #1 of 4 Old 05-01-2004, 03:16 PM Thread Starter
rockon1202
rockon1202's Avatar
I've got 31" by 10" or 10.5" tires on my otherwise stock 98 TJ. Problem is that when I've got the steering wheel cranked all the way left or right, I get a decent amount of wheel rub. Is there any way to fix this without going down a size? I can't afford a lift, so I was wondering if there was some other way to fix the problem until later, without switching tires...
rockon1202 is offline
post #2 of 4 Old 05-01-2004, 03:40 PM
river rat
Forum porn star...I guess
river rat's Avatar
This will do the trick. http://www.stu-offroad.com/misc/steerstop-1.htm
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline
post #3 of 4 Old 05-02-2004, 01:40 PM
MSHarnett
Broke Bogger
MSHarnett's Avatar
Where exactly is it rubbing, if you don't want to adjust the steering stops (loss of turning radius) then maybe you could trim away what ever is rubbing.
Matt
MSHarnett is offline
post #4 of 4 Old 05-02-2004, 03:40 PM
river rat
river rat's Avatar
I'm sure it's rubbing on the LCA's. I don't think he wants to be trimming on those. All you should have to do is add like one washer and that should take care of it. You won't even notice the loss in radius. Troy.
32's vs 31's? (32s= AT/KO vs Pro Comp) (31's= **** Cepek FC IIs vs BFG vs Pro Comp)?? TJoshX Tires & Wheels 4 11-01-2007 08:25 PM
31's or 32' drew2000 Tires & Wheels 3 06-19-2006 09:03 AM
RE 3.5 and 31's Polaris Tires & Wheels 1 12-01-2005 09:37 AM
31's and RE BB method84 Tires & Wheels 7 04-05-2005 06:24 PM
BFG 31's With ???? treehugger Tires & Wheels 3 02-03-2005 09:19 AM
