i really need some help - JeepForum.com
post #1 of 9 Old 04-17-2004, 05:03 PM Thread Starter
Dr Gutiemouth
Dr Gutiemouth's Avatar
ive been trying to put all the data i have gatherd together...
im getting a 2" Budget Boost in a month or so...depending on shipping...
im gonna upgrade tires when money is available: im thinking
these tires:
Mickey Thompson Baja MTX
Size: 32 x 11.5-15LT
Rim: 8-10''
Tread: 8.6''
Section: 10.8''
Diameter: 32.0''
will they fit with the lift and are the tires good and worth 127 a pop?
and these rims:
Cragar Sixer Chrome Wheel
15 x 8
4'' Rear Spacing
5 on 4.5'' Bolt Pattern
are crager rims anygood?
is that good backspacing?
is that the right bolt pattern
all together im paying about 1,200 for lift, 5 rims and tires. is that a good price for everyhting? can i get better for the same amount or less? am i buying junk? am i totally off with my info? please help
-dr clueless...i mean gutiemouth
Green Jeep Club Member #39
The Almighty 2" BB Jeep Club Member #2
*outdated
Dr Gutiemouth is offline
post #2 of 9 Old 04-17-2004, 11:50 PM Thread Starter
Dr Gutiemouth
bump....coff...little help?
*outdated
post #3 of 9 Old 04-18-2004, 08:56 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
Yeah cragar rims are pretty good. I'd get the black ones but thats just me. Get the 15X8 and backspacing may vary, I'm not to familar with needed BS for your vehcile.
The tires are pretty good from what I hear. I'v seen them on several vehicles and the people say they are great for the road, decent on rocks, but suck in the mud. If I remember correctly, they are a bit softer composistion so they may wear a bit fast than a harder tire, but this is the reason for better traction.
Matt
MSHarnett is offline
post #4 of 9 Old 04-18-2004, 10:54 AM Thread Starter
Dr Gutiemouth
is that the right bolt pattern? also, whats conciderd good milage for a soft tire? his web site its long lasting...but of course its gonna say that...so any people running these tires?
*outdated
post #5 of 9 Old 04-18-2004, 11:02 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
Yeah that is the correct bolt pattern. I'm not exactly sure how long they will last. I'm sure they will last you a while depending how you drive, but I'm just saying they aren't going be be as long as a harder tire like BFGs or Goodyears.
Matt
post #6 of 9 Old 04-20-2004, 09:32 AM Thread Starter
Dr Gutiemouth
ok so i found 32 inch bfg's for 128....
so my last question...
will 32" tires be it , the bfg or the mickey thompsons, fit under th jeep with a 2" BB without rubbing or should i go down to 31" to play it safe or what? lil help?
*outdated
post #7 of 9 Old 04-20-2004, 11:39 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
Well just remember a few things. Rubbing can always be fixed by some means. A friend of mine has 32s on a BB but I can't remember if the rims are aftermarket or stock.
Also the bigger tires, the more stress on the axle shafts. The D35s are deffinatly not the strongest axle to have when getting bigger tires. It should handle a 32, but just a possiblilty in making your descision.
Torque is decreased with bigger tires. I have 32s and notice a big diffrence compared to stock. I have an auto tranny so its not that big of a deal. If you have a manual, it will be a bit tougher.
But, bigger tires means more ground clearnace, which is always good. Hopefully someone with a TJ will chime in here cause I really have limited knowledge on a good setup for them,
Matt
post #8 of 9 Old 04-20-2004, 01:30 PM Thread Starter
Dr Gutiemouth
yeah i was wonderin when someone else would help you out...good point with the axle...i dont want rubbing...i guess 31" wont kill me
*outdated
post #9 of 9 Old 04-29-2004, 07:52 PM
Spiderman
Spiderman's Avatar
these tires:
Rim: 8-10''
Tread: 8.6''
Section: 10.8''
Diameter: 32.0''
and these rims:
15 x 8
4'' Rear Spacing
I just put on a RE 2" BB and HAD to go with 30" tires, due to my wondeful 3.07 gears. I was going to go with 32's until I found out the bad news about the 3.07's. Next year I'm planning on going to 4.10, maybe 4.56 gearing with 33's. I'll add a 1" BL and probably a 1" MML. I've got plenty of clearance now, but when I add the 33's, it should still be O.K.
2001 Sport 4.0L, 5 Speed, Patriot Blue
33 X 12.50 BFG A/T's with A/R Atlas 15 X 8 wheels
4.56's, RE 3.5" lift, Currie 1" BL, M.O.R.E. 1" MML
Aussie D30 Locker, & other crap
Spiderman is offline
