how wide a tire on stock 15x6 wheels? - JeepForum.com
post #1 of 10 Old 09-01-2006, 03:31 PM Thread Starter
bkeast17
what is the widest tire I can fit on the stock jeep 15x6 wheels?
bkeast17 is offline
post #2 of 10 Old 09-01-2006, 03:50 PM
rjt36
rjt36's Avatar
2009 JK Wrangler
Stock wheels are 15x7...the upgrade is 15x8. I actually asked the same question over in the lift/tire/wheel/shock section and didn't get much of a response.
I just bought a set of BFG MTs that are 33x12.50R15 and whilst looking at my build sheet I realized I had the 15x7s when I thought I had the 15x8s
So to answer your question: I don't know
rjt36 is offline
post #3 of 10 Old 09-01-2006, 04:18 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I'd probably limit it to a 10.5" tire, 11.5" at the very most.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #4 of 10 Old 09-01-2006, 04:23 PM
rjt36
rjt36's Avatar
2009 JK Wrangler
Wait, Jerry, you're telling me that my 15x7's won't be able to handle the 12.50s? I thought it came down to ability to hold a bead when aired down. If I aired down to a higher pressure than 15psi would that make a difference?
rjt36 is offline
post #5 of 10 Old 09-01-2006, 04:29 PM
Jerry Bransford
Administrator
Who said a 15x7 couldn't work with 12.5"? But that's as wide as I'd go with a 15x7, which is what Igofshn runs. To me, saying a 15x6 max size at most would be an 11.5" is like saying a 15x7 max size at most is a 12.5".
Getting
post #6 of 10 Old 09-01-2006, 05:03 PM
rjt36
rjt36's Avatar
2009 JK Wrangler
oh, okay, I just had myself a small heart attack. Thanks for clearing that up
rjt36 is offline
post #7 of 10 Old 09-01-2006, 05:07 PM
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
put a 305/70R16 on a 6.5" wide rim
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Jakemd98 is offline
post #8 of 10 Old 09-01-2006, 06:31 PM
opticalwaveguy
opticalwaveguy's Avatar
One point that is often overlooked is the advantage of running wider tires on narrow rims. On rocky trails you can effectively decrease your sidewall exposure to sharp trail rocks. The narrow rim "pulls" the soft sidewall "in" away from the tread edge. The hard part is finding the happy medium between this and bead reliability. This is why Jerry makes the recommendation he did.
OpticalWaveGuy
- an online resource for Jeep information
Proud To Be A FF/EMT/Police/Military Club Member #2
opticalwaveguy is offline
post #9 of 10 Old 09-01-2006, 10:32 PM Thread Starter
bkeast17
So any thoughts on mickey thompson radials 35X12.5?? Or should I just get a set of black steelies? The tires are cheap $100 bucks so I can't pass up for a set of mud tires.
bkeast17 is offline
post #10 of 10 Old 09-03-2006, 02:44 PM
Chuck Cook
IMO, I would use the money you saved and buy a set of black spoke 15x8 rims. Watch the backspacing! If you don't understand, be sure to ask. Chuck
95 Cherokee Country (PePe Le Pew) 4.0 Auto
4.56 gears, Aussie Front,PowerTrax No Slip rear (D30/Corp8.25) JKS front discos, no rear sway bar, Rustys t-case skid plate, elastomeric roof coating,
Custom4x4Fabrication rock sliders and diff protectors,
Super Swampers 32x10.5x15 and fender trimming
Chuck Cook is offline
Would... (11.50 wide tire on 8" wide wheel) luv2getbig Tires & Wheels 2 07-17-2009 10:02 PM
32/11.5 tire on 10" wide wheels? ryan2l Tires & Wheels 1 02-12-2009 09:36 AM
how wide of rim do i use on a 14inch wide tire? TXjeepTJ Tires & Wheels 2 05-18-2006 05:17 AM
Can you put 31 x 10.50 tires on stock 15x6 rim? BIGCRAZYBELL Tires & Wheels 14 12-03-2004 09:04 AM
13.5" wide tire on stock canyons boozer1022 Tires & Wheels 2 08-22-2004 04:26 PM
