How to Prep and Rattlecan Paint Pitted Alloy Rims - JeepForum.com
post #1 of 8 Old 11-30-2010, 10:07 PM Thread Starter
shiftclick
I have seen a few write ups on how to paint an alloy rim, but not on how to prep a nasty, pitted one. Pitting happens when salt/dirt gets up under the clearcoat of an alloy rim and basically corrodes the surface. Here in Iowa, we get a TON of road salt on our heaps in the winter, so this project required a little "tougher" solution than the norm usually requires.
So, to get started - a little back story:
I had been running a 2" BB and a 1.25" BL on 31" BFG AT's on the stock "Grizzly"/"Ecco" rims for years and never really had a problem with it. The problem started one day when a coworker told me he saw some "huge" tires at a garage sale on the way to work and that they were going for cheap. I asked how big and he held his hand up to my shoulder… and I KNEW he was full of crap.
So on a break, we jumped in his YJ and cruised up the road to where he had seen them, and low and behold, here were 4 x 33x12.5x15 mud terrain tires sitting on American Racing Rims. The little sticker said "$125". I walked over to a man sitting at a table and he directed me to his daughter. I asked her if it was $125 for each one or for the lot and about fell over when she said $125 for all. These were VERY gently warn (Peerless) Widetrack Baja M/T's that still had the nipples on them. Smelling a rat, I asked her if anything was wrong with them, and her Dad piped up and said one had a sidewall puncture. After that I countered with $100 and she excepted.
Follow my thinking: I could always find another 33" and use a tube in the sidewall punctured one and use it as a spare, or I could sell each 33" for about $80 and all four rims for about $200! That's $340 profit!
So here's my prize:
Now, i'm kinda a cheap guy. I only buy things if I absolutely have to and would rather do anything myself than to pay someone else to do it. That being said, I always wanted a set of 33"s and here I had some sitting in my garage. The first thing I set off to do was see if the sidewall puncture was high enough up that it was repairable. I took it to 3 local shops and everyone of them said they wouldn't touch it with a 10 foot pole. I had then had a buddy of mine who used to work in a tire shop try to work his magic on it. The morale of the story here - and those of you that know a thing or two about tires is - ITS NOT REPAIRABLE AND EXTREMELY DANGEROUS TO RUN ON IT EVEN TUBED.
So back to the drawing board I went. While I waited to find a suitable replacement, I thought i'd throw one of the good wheels up on the jeep to see how they looked. Sure, they were whitewall out but I was going to take them in and get them flipped and balanced anyway.
Well imagine my surprise when I realized they were a 5 x 5 lug pattern that wouldn't fit my 02' TJ's 5 x 4.5 lug pattern! Crap and double crap!
Dejected, I told my friend Craig about it and I told him that I guess I could use spacers and he told me that he thought he could help. He told me not to use spacers, but that he had just thrown a set of bead locks on his 99' TJ and that if I was willing to clean them up (and subsequently get them out of his garage) that I could have his old American Racing Baja rims! SCORE!
Here's a shot of one of them. They are pitted and pretty nasty and have quite a bit of rim road rash from Craigs previous excursions, but nothing that should be show stopper. I was able to use the Dremel to whittle down some of the larger gashes along the edge of the rim. Like I said, nothing major.
He's such a nice guy, he even threw in an old steelie he had laying around so I could eventually use it on my spare. Great guy, that Craig.
The next day, I unloaded my booty and grabbed some scouring powder, billow pads and brushes. After two hours and finishing only about 1/4 of a rim, I decided that I needed to do a bit more homework. Jeepforum.com to the rescue. I found a whole slew of DIY rim prep, but they all called for 300 grit or better sand paper. I had 100 grit and 300 grit in the garage, so I started with the 100 grit. After all, I was going to be priming and painting them so 100 should not do too much damage.
After about 2 full sheets of 100 grit and using a Dremel with a sander attachmate for the lug nut holes, I washed it down with some soap and water and I had this:
At this point, I had pretty much decided that there was no way in hell I was going to even try to clean up the back of these things. I also decided that I wasn't going to paint them either, so this project should be moving right along.
Once I cleaned up the outside of each rim, I set to work on the bead side of the rims. The one thing to note here is that you need to get all of the old rubber, dried slime and bead seal off in order to ensure that you get a good seal with your new wheels.
Dirty:
Clean:
After doing some more research on JF, I elected to go with Rustoleum branded Self-Etching primer (2 cans) and Rustoleum branded flat rattle can paint (2 cans). I even sprang for the handle/trigger thingy to make it easier to spray.
After washing and air drying all four rims again, I set them out in the sun to dry for a few more hours. Next up, I wrapped the outer, wheel side of the rim in painters tape and newspaper but elected not to do anything with the inside of the rim (the underside) as there really shouldn't be much overspray through the wholes of the rim.
Before I taped off the other 3, I decided to lay out a tarp in the single stall side of the garage and closed the door, leaving the main double-stall side of the garage open for some air circulation. Having never messed with self-etching primer before, I wanted to do at least one test spray on a rim to see what it did.
I hit it with one coat and let it dry:
It looked fine, so I continued on taping and prepping the other 3. At first, I was going back over the first rim with 5 or 6 light coats from about 10 inches away about 2-3 minutes apart. This was working perfectly, so I started on the rest of them.
I followed the directions on the back of the self-etching primer can and let them all sit four about 4 hours. They dried nicely and had a kind of cool, green look to them.
I then spot checked them in the better light to make sure I hadn't missed anything. They all looked great, so I proceed to attach the flat, black rattle can to the sprayer trigger thingy.
I followed the same steps: 5-6 light coats from 10" away on each one about 2-3 minutes apart. 30 minutes later and I was ready to let them sit over night.
The next day, I came out and checked them out. I had sprayed too light or missed the inside edge on all four rims and re-sprayed each one and let them sit again.
Four hours later, happy with my work and after verifying they were dry, I headed up to good ol'Wally world and had them remove the 4 old rims and mount up the 3 "new to me" ones. I still hadn't found a 4th 33", but knew I would soon.
Here's a shot with one mounted up on a dirty wheel:
About a week later, after posting something on my clubs board, a nice lady and her husband informed me they had a 33" I could buy for $50. I met up with them and then ran the tire and rim up to Wally World and then returned home to mount them up. I then took them for a quick ride (it was pretty late but I wanted to hear how bad the road noise was). I was PUMPED to see them in the daylight!
The next morning, I snapped these:
The best part is this: I sold the 31 BFG AT's (no rims) for $400, sold the rims for $200, and sold the 5x5 AR rims for $100. So out $100 for the 33's, then out another $50 for a 4th less mounting and balancing means I got an almost brand new set of 33's with rims for -$550!!! Not bad!
So, that's pretty much it. I guess one thing to note is that if you wanted to, you could clearcoat after letting the final black dry. But for me, I beat the crap out of these wheels, so being able to clean and then touch up with a rattlecan o'flat black is my kind of maintenance!
Shiftclick
His: 2002 TJ 4.0L (Sold), Hers: '10 XK Hemi Ltd
I'm currently between Jeeps...
shiftclick is offline
post #2 of 8 Old 11-30-2010, 11:23 PM
KKiowaTJ
Looks good considering our idiot state dumps so much its like the salt flats. You must be up in the QCA as you said you could get a shop to hot patch your tire and tube it. There is nothing wrong with a tube, I know many people who run them from new. Too many shops are scared to mount used tires as they think they will get sued, That and they want to sell ya a new one. I would get a tube and use it for your spare. Unless its a tear it can be patched and tubed.
Wheels look great though and the finish can be touched up after this winter salt slicks. I'm trying to get my rig ready for the rust and crap weather.
MOPAR!
KKiowaTJ is offline
post #3 of 8 Old 12-02-2010, 10:37 PM Thread Starter
shiftclick
Man, we tried for almost a month and a half to patch it! It's a knife puncture. You can literally see the shape of the blade. But it's pretty high up near the "sidewall tread". I'll keep trying though! Wish me luck!
Shiftclick
post #4 of 8 Old 12-03-2010, 01:51 AM
KKiowaTJ
That sucks! Since you have a replacement on your jeep and i know it would be better to have matching make it your spare. No harm in limping off a trail or driving home on knowing its flaws.
If you cant find a place theres always a hillbilly hot patch followed up by a tube. The tube alone would get you off the trail and your discretion road wise. But go to a swimming pool store and get a good patch kit for a vinyl pool. Get a pistol grip sander and rough up the cut on the inside. You might have to get adhesion promoter if it dont come in the kit.
I have done it many times for farm tires and the like. You can use a patch cut from a bicycle tube if you find a good bonding agent, But still needs roughed up for a course area to adhere to.
But good luck either way, Eventually you will find a good tire shop.
MOPAR!
KKiowaTJ is offline
post #5 of 8 Old 12-03-2010, 11:28 AM Thread Starter
shiftclick
Thanks for the advice KKIowaTJ! I will give it a shot this weekend!
Shiftclick
post #6 of 8 Old 12-03-2010, 07:15 PM
KKiowaTJ
No Problem. But this type of fix is for low speeds and spare only. The temperature of the tire and outside will play a factor so if you can get it to 60 or better, Faster it will cure and adhere.
I forgot to add, The hole on the outside from the knife, To prevent moisture, Mud, Salt etc from getting in there and possibly deteriorating the patch. I have used clear silicone or ultra black gasket sealer and fill in the hole after the patch is dry. Its just a cheap way to get by and in my case i would be broke if i bought a new tire every time the farm claimed one. Good luck
MOPAR!
KKiowaTJ is offline
post #7 of 8 Old 12-04-2010, 01:05 PM
terpsmandan
2009 JK Wrangler
Looks good. I just rattle canned a set of these with Duplicolor wheel paint. A little 320 grit, some elbow grease and bottle of prepsol. I'm getting a set of Winterforce snow tires for those so NY salt won't kill my good rims.
terpsmandan is offline
post #8 of 8 Old 12-05-2010, 11:44 PM Thread Starter
shiftclick
Very nice! Let's post up pics post-salt season and see how each set holds up!
Shiftclick
Prep for paint. fmrplt General Jeep & Off-Road Equipment 10 10-02-2007 10:12 PM
Rattlecan with factory paint on old doors Bosch General Jeep & Off-Road Equipment 2 03-21-2006 09:08 AM
Touch up paint prep erickpl General Jeep & Off-Road Equipment 2 10-05-2005 10:21 AM
What to use to prep/paint frame jeepdad56 General Jeep & Off-Road Equipment 6 09-28-2005 09:30 PM
Paint prep? Mud4U General Jeep & Off-Road Equipment 4 07-04-2005 12:09 AM
