How-to: Mount tires on beadlock wheels.
| DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series |
#1 | ||
Now in the 937
Figured I'd do this for JF as there is a lot of questions on them.
I'm installing 40" Swamper LTBs on 17" Allied Beadlock wheels. Here's the basic steps to install them. I won't go into great detail concerning torquing pattern as you need to go by what the manufacturer of your wheel says. Mine is a crossing pattern like 12, 6, 3, 9, then one over from each of those in that order, etc. Shaynea was awesome and got a bunch of pics of the beadlock install process: ![]() ![]() ![]() ![]() ![]() ![]() ![]()
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase Build thread here. Quote:
Pictures of it wheeling at Bill's 491 And more pics from that trip here! |
#2 | |
Now in the 937
After you're done unpacking all your goodies, now it's time to pull the valvestem through. I can do it w/ a pair of side-cutters without galling the threads because I'm crazy awesome like that. A valvestem installing tool is quite nice to have but I'm not about to go out and buy one for 4 wheels.
![]() ![]() ![]() Now the fun part... lay the tire down over the rim(note: lubing the inner bead w/ soapy water works wonders, I did this one dry as it had a bit of goo left from the tire forming process): ![]() Now hump it into place: ![]() Until you achieve victory: ![]() Then I moved everything over a bucket to make everything easier for bolting the beadlock ring on: ![]() ![]() Start gathering bolts. Chances are you'll need 2-4 longer bolts to get everything started. I had some longer bolts but they were a bit too long, I just put washers under them to make them usable. ![]()
#3 | |
Now in the 937
My "starter" bolts compared to 2 of the supplied beadlock bolts:
![]() Before that if you're putting any balancing beads in, now is the time to do so. I measured out 14oz of steel BBs for each. ![]() Started: ![]() Keep in mind to ensure the tire is nice and centered in the ring. ![]() ![]() ![]() ![]() Note I used an impact to get them all started and to speed things up(not recommended by manufacturer). I learned from the first wheel about how far down the bolts need to go so I wouldn't go past. I DID do everything by hand on the first wheel. Always do the final torquing w/ a torque wrench in the manufacturer's recommended pattern. I did mine to 15 ft-lbs(spec is 12-15 ft-lbs). ![]() I still need to do the final torquing about 2 more times as my back called it quits for tonight, but you basically do that 3-4 times total. Then check it again of course. This is because you are compressing rubber. Tighten one bolt, and it loosens about 4 more. Eventually you'll get to the point where everything is in the 12-15 ft-lb spec and you can call it good. Air up the tire and check for leaks. I'll recommend airing it up while standing because sometimes the inner bead seating can be violent. On some car wheels it has enough force to shoot the entire wheel/tire off the ground. ![]()
#4 |
Need more pics of the carton from different angles
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times. |
#5 |
Beadlocks
Very nice writeup,well done, good pics.Tires and wheels look great! I just find one problem with your build,why steel BB's? They will rustout in time and turn to dust+ the noise factor when they drop and hit the rim.Whynot airsoft pellets? I have 35/15.50/15 TSL/SX'S and MRT 10" beadlocks with 20oz. green airsofts in each and they work great.No rust,lower noise factor(still some though) No balance issuses at all. I hope they workout for you.
99' 2DR,Chopped+Caged,stripped and herc'ed .Custom LA's 7"RK coils+2"spacer,S10 leafs,RR 1.5 shackles,Locked F+R,Alloys,4.10's,Woods shafts,D44 with ZJ discs,custom rockrails and rear bumper,Hanson front with 9500Ti amsteel blue rope,Piaa lights,7" Warn TJ flares,35/15.50/15 TSL/SX'S on MRT Beads etc.etc.etc......... 97' Dodge ext.cab longbed 2500 4x4 360 flowmaster duals,Tow rig. Two Rivers Jeep Club Pittsfield,IL TRJC.com |
#6 | |
Now in the 937
I think 14oz of airsoft pellets would be something around 4000-5000 per wheel. Having that many and possibly not needing all 14 oz I THINK would cause some pellets fighting for a certain spot and not balance as a result. Less balancing media volume-wise I think would be more tolerant to over-filling.
They're zinc-coated so they won't rust out immediately. Even once that coating wears off, them being constantly rustled about should keep most rust from building up. The noise won't bother me... I'm driving 40" Swampers and a cut up Jeep ![]()
#7 |
Im going to use airsoft bb's. The .20gram ones are good. I was able to make 5 14oz ziplock bags with two of the 5,000 count containers and had a few left over.
#8 |
Great write up, nice to see how it was done, dont they have a ballancing sand too?
My Build www.jeepforum.com/forum/f22/building-roxy-860189/ |
#9 | ||
Now in the 937
And yeah, it's called Equal Balancing Powder IIRC. I chose not to use it because if you get any moisture in the tire I imagine it will clump up and not be as effective. Also don't want a white cloud of powder to cover me when I air down ![]()
#10 |
I have 35's been told 10.5 oz of steel or copper BB's per tire, is that the right weight and amount for the 35's and bead locks? or should I get 14oz. thanks Jeff
79 CJ5 7"lift, Dana 44's front and rear 4.88 gears, 35's on true bead locks. Colorado jeep club member # 186 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
