How many wheel lug stud threads is enough? - JeepForum.com
post #1 of 4 Old 04-15-2006, 01:00 AM Thread Starter
'99RedXJ
Adoro mi Jeep
'99RedXJ's Avatar
I just finished bolting on the Wrangler alum. rims on the XJ. Of course the alum. rim is thicker than the steelie stockers. It seems like I'm only getting 8 threads on the alum wrang rims and was getting 12 on the steelies.
Is Eight Enough??
Any thoughts on this or is there a tech thread somewhere?
Tony
99 Red XJ Sport 3" inch lift
S-10 Leaf Swap
Rear BPE's w/ Rusty's r26 shocks,
Front Rusty's 300 coils w/ r27 shocks.
BFG 31/10.50x15 TA/KO
5" to 5.5" Total from stock mesurement
Front rubs at full lock
'99RedXJ is offline
post #2 of 4 Old 04-17-2006, 01:09 PM
leonw
I don't know if 8 is enough but I only had 5 or 6 threads when I switched rims. I bought some new longer studs and pounded the old ones out. Made me feel much much better.
leonw is offline
post #3 of 4 Old 04-17-2006, 01:19 PM
JeepCollector
I'm sure that Jeep didn't have different studs from the factory depending on which wheels were on the XJ. If you are really concerned try fitting an XJ aluminum wheel on your vehicle to compare or look at a Wrangler with the same wheels you have now to see how many threads there are. Unless they are aftermarket wheels I don't think you have a problem.
JeepCollector is offline
post #4 of 4 Old 04-17-2006, 03:16 PM
TJeeper
TJeeper's Avatar
The same length as the diameter of the stud, or in your case, 1/2". You can change the studs, or get extended length lug nuts.
http://www.billetspecialties.com/ite...cid=26&pid=679
I would also recommend the thin wall socket (you need 13/16"), your regular socket may not fit.
Patrick
TJeeper is offline
Wheel adapter stud torque nbrege Tires & Wheels 8 06-24-2009 03:49 PM
Wheel stud question? dale88 Tires & Wheels 5 11-18-2008 02:57 AM
Wheel stud loose and spinning VaDon Tires & Wheels 2 05-04-2007 05:00 PM
replacing wheel stud gojeep99 Tires & Wheels 5 12-08-2004 02:56 PM
Wheel stud lubricant HMTwin Tires & Wheels 3 08-26-2004 04:45 PM
