How do tire bead locks? - JeepForum.com
post #1 of 10 Old 06-28-2010, 06:37 AM Thread Starter
TeeJay00
I was reading the "Idaho Jeep Build" post and I saw those bead locks he installed.
I know what bead locks do but I was curious to know more about them. Can someone please explain to me how those work? What are the beads for? And do they have to be used with specific type of wheels or any wheel can hold those locks?
Again thanks
TeeJay00 is offline
post #2 of 10 Old 06-28-2010, 06:39 AM
BriansCJ
1994 XJ Cherokee
They balance the tire, so you dont have to have a shop put weights on.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #3 of 10 Old 06-28-2010, 06:42 AM Thread Starter
TeeJay00
Does it really work?? Why not keep using weights?
TeeJay00 is offline
post #4 of 10 Old 06-28-2010, 07:31 AM
Idaho-Jeep
*How these bead locks work:
That big black flat circular thing (called the "bead lock" by Hutchinson) is a ring that sits on the inside of the tire beads. When the two pieces of the wheel are bolted together it sandwiches the tire bead between that ring and a lip on the wheel. This sandwich creates a vice like grip on the tire bead not allowing it to pull out.
These beadlock wheels are unique in that they lock both the out and inner tire bead. Most bead locks only lock the outer bead using a metal plate ring that then bolts down to the wheel sandwiching the tire bead between the wheel and the metal ring.
*Beads
Those beads are indeed for balancing. I decided to use them because 1) I didn't want the lead weights which can often come off when going through rocks etc... 2) Sometimes balancing big tires with lead weights is expensive and difficult to balance in general. 3) Probably the main reason is that I wanted to do it all myself... Using the beads and bead lock wheels allowed me to mount and balance my tires myself... these tires/wheels have never been to a tire shop. This technology has been around for a long time.. Many big rigs use these beads for balancing their tires... And yes, my tires balance great!
Idaho-Jeep Build =
Idaho-Jeep is offline
post #5 of 10 Old 06-28-2010, 07:47 AM Thread Starter
TeeJay00
*Beads
Wow... I'm flattered that you responded to my post and so quickly What are the odds on that huh?
First allow me to say that your work is magnificent thanks for sharing it with us.
So back to the subject, those locks aren't something you can add to any wheel instead of buying new bead lock wheels. The secret is with both the black inner lock and the outer rim of the wheel, right?
TeeJay00 is offline
post #6 of 10 Old 06-28-2010, 07:56 AM
mdm
Farm Wheeler
Originally Posted by TeeJay00 View Post
...those locks aren't something you can add to any wheel instead of buying new bead lock wheels. The secret is with both the black inner lock and the outer rim of the wheel, right?
You've got to buy the wheels.
Hutchinson Wheels - Quadratec
Hutchinson / Rock Monster Wheels -
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #7 of 10 Old 06-28-2010, 08:14 AM
Idaho-Jeep
Ha - just happened upon it Its a morning ritual to check TJ tech page.
Thank you - but everything I have done on my jeep is not all that magnificent... Anyone could easily have done the same... taking the time to read and understand before buying and doing is really all I did before/during and after my build.
Nope... but I believe people have made their own bead locks using the metal plate ring I described above and a stock wheel. I think that would be difficult and require some skill however... best bet would be to buy a set of beadlocks new....
Idaho-Jeep Build =
post #8 of 10 Old 06-28-2010, 08:24 AM Thread Starter
TeeJay00
Got it Thanks for all the info Idaho-Jeep
TeeJay00 is offline
post #9 of 10 Old 06-28-2010, 09:04 AM
Zen
TeeJay00
Just to clarify...
A tire bead is the edge of the tire that contacts the wheel. It is typically thicker than the sidewall.
Dyna-beads, are balancing beads. They are an active balancing agent that moves to constantly rebalance the tire. You can not use steel wieghts on a tire with active balacers inside, because the tire balancing machine does not measure the tire correctly and you will never get a 0-0 balance. Some people balance the tire first, then add beads, but that only addresses the initial balance and as the tire wears could cause more harm than good.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #10 of 10 Old 06-28-2010, 01:58 PM Thread Starter
TeeJay00
Originally Posted by Zen View Post
TeeJay00
Just to clarify...
Yes yes thank you for clearing that I am aware though of those definitions specially after I googled this subject yesterday
But bead lock wheels and other accessories like those are almost impossible to find over here and when I saw those inner locks I figured this could be my answer to lock my tire beads to the wheels I already have !
Anyway... Those Hutchinson wheels look amazing. I might have a set shipped all the way over here one day (added to future mods)
My only remark on them is that they don't make them wider the 8" on 15's and the backspacing isn't that good, or is it?
I'm currently running 15"X10" wheels...although I forgot the backspace size on them but they are perfect for my normal lift.
TeeJay00 is offline
beadlock
Rubicon Low Rider. Can I remove the springs? Custom spinners work with bead locks? jondotcom Wrangler General Discussion 9 10-27-2009 05:08 PM
Staun Bead Locks - installed MichaelW JK Wrangler Technical Forum 2 04-27-2007 10:28 AM
Full Traction lift, 35" bead locks Slc JK Wrangler Technical Forum 4 03-09-2007 09:08 PM
Maxxis Trepadors and bead locks Stu Olson TJ Wrangler Technical Forum 16 02-20-2007 11:02 AM
Legal Question - Bead Locks and Fender Flares MoTJ TJ Wrangler Technical Forum 2 05-20-2002 06:39 PM
