How to determine correct tire psi - JeepForum.com
post #1 of 4 Old 07-22-2012, 01:47 PM Thread Starter
99WJdan
Recently got new tires and am worried about overinflation and under-inflation. The door panel says 33psi. Tires are Treadwright Guard Dogs 265/75/16 load range D. Right now they are at 35psi I believe. Should I lower it or raise it? The Jeep drives like a champ the way it is now. Looked at the tires while driving and you can easily see the sidewall flexing.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #2 of 4 Old 07-22-2012, 04:29 PM
Ironhead
do a chalk test or a puddle test
Ironhead is offline
post #3 of 4 Old 07-22-2012, 04:35 PM Thread Starter
99WJdan
By puddle test, you mean drive through a puddle then look at the print? Sounds simple enough.
99WJdan is offline
post #4 of 4 Old 07-22-2012, 04:59 PM
Ironhead
yep, nice and slow, only need to roll 10 feet or so
Ironhead is offline
