How aggresive are the Falken Wildpeaks? - Page 4 - JeepForum.com
post #46 of 86 Old 06-01-2012, 11:28 AM
Dallas333
Originally Posted by WXman View Post
Got 7,000 miles on mine now. The more miles on put on them, the less I like them.
Cons:
-Much heavier than competitive ATs. Is KILLING my gas mileage.
-Continuous flat-spotting/balancing issues. Cannot get these to balance. Not going to bother sending any more tires back for replacement.
-Miserable offroad traction. Mud, damp dirt, roots, loose soil, just horrible traction. Not a good eastern U.S. trail tire at all.
-They pick up gravel worse than any other tire I've ever used. My rock rails and rocker panels and doors are taking a beating. Plus, the constant "tick tick tick tick" traveling down the road.
Pros:
-Low price
-Thick sidewalls
-Quiet on the road
-Wearing great so far
At this point I'm 100% sure I'll never buy them again. Out of the 18 or so brands/models of tires I've used, these are the first ones I've told myself I'll never buy again. Now I know why the Sumitomo AT was discontinued...they weren't selling them so they slapped the general tread design on a Falken branded tire and promoted it as something new, but the quality is still shoddy.
What size do you have? I know we did a weight comparison on all of the 16's and they weren't any heavier than most of the other AT's.
1999 Chili Pepper Red TJ, 4.0, 5 speed, 4 inch Pro Comp lift.
Disclaimer: We should all have hope and look towards the day where man realizes that the sounds exiting his mouth are mostly complaints and a change occurs. - Chevelle
Dallas333 is offline
post #47 of 86 Old 06-01-2012, 12:05 PM
WXman
I have 285/75-16. Two weighed 62 lbs., and two weighed 64 lbs. (further proving the manufacturing quality is low). By contrast, 95% of ATs in this size go 51-58 lbs. As much as 10 lbs. heavier per tire...that's significant.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #48 of 86 Old 06-01-2012, 04:00 PM
DiscountTire
Vendor
DiscountTire's Avatar
I realize that no tire will be good for everyone but I've got the same question for you as on the other forum. What pressure are you running them off-road? Tire pressure has a large effect on a tire's performance especially when you have a tire with a strong sidewall. I run mine at 12 psi off road and they grip like a champ. I'm not just saying that because I work for a company that sells them. These tires really have been excellent for me.
Low Prices! More Choices! FREE Shipping!
At The Store:
To Your Door:
Sales and Technical: 1.888.459.4080
Useful Links:
DiscountTire is offline
post #49 of 86 Old 06-01-2012, 07:59 PM
Profit42
Sounds typical for Falkens.
Profit42 is offline
post #50 of 86 Old 06-01-2012, 09:47 PM Thread Starter
Kodiak17
WXMAN, can you delve into the subject of MPG loss and give a little more detail?
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #51 of 86 Old 06-02-2012, 08:55 AM
WXman
Everything you read says that 10 lbs. of unsprung weight is the equivalent of adding 100 lbs. load into the back of the vehicle, in terms of fuel economy, power, and braking. I don't know if that math is correct or not... but that's the rule that is passed around on the Jeep forums all the time.
So, assuming that is true, I'm running 40 lbs. of additional unsprung weight by choosing Falkens over another brand of AT. That's like carrying 400 lbs. around in the back of the Jeep all the time as far as my gas gauge is concerned. That's a BIG deal.
On my daily routine, I was averaging 19.2 MPGs in bone stock form. With the Falkens I'm at 16.0 if I baby it...and 15.2 if I drive it like I want to on the same driving route to/from work and play on the weekends. The 4.88s didn't do anything for my mileage pro or con...they just help me hold overdrive on the highway now, but my mileage hasn't changed hardly at all due to the gears.
So, it appears that I lost 3-4 MPGs from the Falken tire upgrade. Now, if I went with a lighter AT tire of the exact same size..how much would I gain back? Probably not much...around 1 MPG probably. But every 1 MPG is worth $20/month to the average person...so choosing a different AT tire would pay for itself FAST.
For that reason (and the others I listed) I'm going to try the Nitto Terra Grappler. It's listed at 53 lbs. each and has great reviews. I already have one for my spare...and as my Falkens die I'll get more Nittos to replace them with.
If my JKU was a trail-only vehicle I'd have MTs on it. But since it's not I have to be conscious of efficiency and ride comfort in addition to trail prowess...and the Falken just isn't getting it done.
WXman is offline
post #52 of 86 Old 06-02-2012, 09:27 AM
bhoch
With my Falken WildPeaks my MPG did go down. It went from 19.5 (roughly) to 18.5 (roughly) on my daily commute. My DD is 55 27 miles each way to work and back Monday - Fridays. I have the 305x70x16 wildPeaks with no other options and 3.73 gears. I like them, actually. Find them very quiet, at least for the Central Texas roadways that we have. I only have about 2500 miles on them, so it will be interesting to see how they are once they wear some. I run them at 28 PSI on the road, have not been off road enough with them to know what I need to run at then. I have not had any issues with them so far. Will be interesting to see if they make any improvements in weight or tread designs over the next year(s) with these.
Like WXMan I too find them very heavy and I will probably go with a different AT tire whenever I need to replace these. But that will be a while. Other then weight, I am happy with them so far. I have a while to go before I can consider a different tire, as these look like they will wear slowly (which, coming from sports cars is a nice change!).
bhoch is offline
post #53 of 86 Old 06-02-2012, 04:53 PM
xjknight
Some people want durability for offroad use.. Some people want lower weight.. Can't really have both so in the end it's up to the buyer what they want. Wether it be something light weight but can be easily damaged like a duratrac or something that is heavier and more durable like the wild peak at, st maxx, and most MT's.
-XJ- 2001 Jeep XJ Cherokee - Gone
CF: Begrüßen Sie Hitler.. WF: Самый прекрасный коммунизм.. Pirate4x4: Oh Canada.. JF: Fail Rated
xjknight is offline
post #54 of 86 Old 06-03-2012, 09:13 AM Thread Starter
Kodiak17
I want the Falken's but the weight has me convinced on another tire. Most likely a 33x10.50 KM2.
Kodiak17 is offline
post #55 of 86 Old 06-03-2012, 11:57 AM
Dallas333
285/75/16's
Falken Rocky Mountain ATS - 62 lbs/tire
BFG All-Terrain T/A KO - 59 lbs/tire
General Grabber AT2 - 62 lbs/tire
Goodyear Wrangler Duratrac - 58 lbs/tire (there are two different kinds on tirerack, one weighs 58 one weighs 54)
BFG Mud-Terrain T/A KM2 - 59 lbs/tire
Dick Cepek Mud Country - 61 lbs/tire
305/70/16's
Falken Rocky Mountain ATS - 67 lbs/tire
BFG All-Terrain T/A KO - 61 lbs/tire
Goodyear Wrangler Duratrac - 63 lbs/tire
Dick Cepek Mud Country - 63 lbs/tire
So yes, looks like the 305's in the Falkens are much heavier... in the 285's though, not bad.
post #56 of 86 Old 06-03-2012, 02:41 PM
xjknight
Interesting.. Very interesting
xjknight is offline
post #57 of 86 Old 06-03-2012, 05:45 PM
WXman
Originally Posted by Dallas333 View Post
285/75/16's
305/70/16's
The mistake here is that you're comparing apples to oranges. The 285/75 Falkens are load range "D". The BFG and most other tires you listed are "E". If you consider that the lighter capacity Falkens are heavier than the higher capacity competitors, the issue becomes obvious.
Like I said earlier in this thread... I've collected weight data directly from the manufacturers by emailing them or calling them, and what I've found is that 95% of the ATs out there in the 285/75 size are 51-59 lbs...with most of those being in the low to mid 50s. By contrast, the Falkens are almost 10 full lbs. heavier.
WXman is offline
post #58 of 86 Old 06-29-2012, 03:58 PM Thread Starter
Kodiak17
I wanna hear more about mpg's. Anyone run KM2's to compare? They are my other option. I do a lot of highway driving, I know the Falkens are nice for that in the sense of comfort and performance but not MPG.
Kodiak17 is offline
post #59 of 86 Old 06-29-2012, 04:08 PM
Dallas333
I went from crappy 30x9.5x15's to 285/75/16 Falkens and my gas mileage has not suffered much at all. They are quiet and handle well for me on the highway at all speeds. Before i got these, my mileage was at max 15mpg... With these, it MIGHT be about .3 mpg less. I couldn't turn them down for the price.
post #60 of 86 Old 06-29-2012, 05:55 PM Thread Starter
Kodiak17
Have you done any hard wheeling with them? If so what kind?
Kodiak17 is offline
falken wild peak tony1959 Tires & Wheels 19 01-24-2014 08:33 AM
Falken Wild Peak AT vs. Falken Rocky Mountain ATS WXman Tires & Wheels 20 06-05-2013 04:09 PM
Falken AT tires neo1973 Tires & Wheels 8 10-27-2010 04:28 PM
New Falken A/T??? JRussum Tires & Wheels 3 05-26-2009 02:25 PM
Aggresive Tire realdeal176 Tires & Wheels 9 04-11-2007 11:10 AM
