how to adjust track bar??? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > how to adjust track bar???
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!
Unread 11-22-2005, 06:53 PM   #1
BORY
TJ Wrangler
i have a bad case of bump steer and swerving while driving i think called the same thign but anyways im pretty sure its my track bar. i was jw if anyone knew how to adjust a skyjacker fron track bar?
BORY is offline   Reply With Quote
Unread 11-23-2005, 09:21 AM   #2
In the open
You need a good 4x4 shop to dial in your front end. If you haven't, replace the steering dampener shock with a good one at the same time it will help. Have you had an alignment?
[I]Jeep owners do it in the open[/I]
2004 Sahara, auto,D44, 3.73, tracloc,4wdiscs,31" MT/R
REBB,JKS Disc,Warn oil pan skid,Warn fuel tank skid
Mopar rock rails,15x8 eagle alloys
[URL=http://www.cardomain.com/ride/2149388]Our Jeep pics[/URL]
In the open is offline   Reply With Quote
Unread 11-23-2005, 09:49 AM   #3
mdm
Farm Wheeler
Do you have a dropped pittman arm installed? If you do, that is most likely the cause of the bumpsteer. Remove it and put the stock pittman arm back on and get the alignment checked.
mdm is offline   Reply With Quote
Unread 11-23-2005, 10:30 AM   #4
river rat
Forum porn star...I guess
river rat's Avatar
Or do it yourself and save some money. Your trackbar adjustment won't cause the symtoms you are describing. The guy who posted about uninstalling the dropped pitman arm is right on.
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline   Reply With Quote
Unread 11-23-2005, 02:16 PM   #5
BORY
TJ Wrangler
wouldnt putting the old pitman arm on put more stress on the steering parts since it would create a larger angle. and i noticed the other day i had my dad move the steering wheel a bit and there is play in the wheel the only thing moving was the steering shaft going to the steering box nothign else was moving. any ideas about that??
Unread 11-23-2005, 04:50 PM   #6
TellyDSP
Poland and PPV!!!!
bump steer can be caused by your trackbar and draglink(at least in YJ's) not being parallel. Adjust it accordingly.
Check the u-joints on your steering shaft. They could be shot. Could lead to similar symptoms I suppose.
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline   Reply With Quote
Unread 11-23-2005, 10:06 PM   #7
river rat
river rat's Avatar
Not on a tj. Unless you have like 5-6" of lift, you need to keep the stock pitman arm on.
Unread 11-24-2005, 06:00 PM   #8
BORY
TJ Wrangler
thanks. if that doesnt work what else could it be??
Unread 11-24-2005, 11:47 PM   #9
river rat
river rat's Avatar
It'll work..................
Unread 11-25-2005, 11:00 AM   #10
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Going back to the OE Pitman arm will cure your bumpsteer. I wish I had a dollar for every time I've said this to TJ owners who installed a dropped Pitman arm.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 11-28-2005, 06:36 PM   #11
BORY
TJ Wrangler
so if just take the old one off and replace it with the new stock length one i dont have to do anythign or i have to do an alighnment b4 i drive it??
Unread 11-28-2005, 06:37 PM   #12
BORY
TJ Wrangler
Unread 11-28-2005, 07:08 PM   #13
Jerry Bransford
Just position the replacement Pitman arm so it is pointed exactly the same as the old Pitman arm was and then straighten the steering wheel as per the easy instructions at http://www.4x4xplor.com/alignment.html
Getting Savvy...
