Quantcast high steer - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > high steer
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 02-22-2004, 08:41 AM   #1
mean green
high steer
I've gotan 85cj with dana44's and need to go to high steer.
right now i am all over the road. what do i need to do the high steer and what is involved in it?
1985 cj-7,256, t-176,dana 300, dana 44's f & R ,detroit lockers f&r, 4.09 gears, soa with 4"suspension lift,2" shackle extention,shackle reversal,custom 3"x5" straight frame, custom roll cage with tire rack above, fiberglass body,35"s.s boggers,ramsey 8000lb winch
mean green is offline   Reply With Quote
Old 02-22-2004, 04:24 PM   #2
Devious
Hobo
Devious's Avatar
1996 YJ Wrangler
The only way high steer would help is if you bought all new steering parts. It would be more cost effective to fix you're current set up.
Edit: I just noticed that you are SOA. I'll let someone who knows what they are talkin about chime in
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline   Reply With Quote
Old 02-22-2004, 06:01 PM   #3
bigsteve3184
First you need to find yourself some flat top Chevy knuckles. I can't remember the exact dates 73-76?, (research) but you can usually find them on E-bay. Be careful if you buy them there, make sure that BOTH knuckles are Drilled, Milled, and Tapped. Then you will need some Hy-steer Arms. I got mine from www.shakerbuilt.com. It wouldn't hurt to go ahead and buy the 1" spacer for the arms as well. You will need the Studs and Bolts too.
The Hy-Steer arms are made with 7/8" TRE, so you will need to buy or fab up some new steering too. Make sure you connect your drag link to the knuckle, it will completely eliminate bumpsteer. In order for the huge 7/8" TRE to go in your pitman arm, you will need to ream out your pitman arm. You can get a the correct reamer from Snap-On I believe its part number R121..... I think.....
I think thats all....Good luck to you....
95 YJ 2.5L
SOA/2" BDS Springs/ 1" body
D44 ARB/Ford 9" Detroit Locker/5.13/ 36's
www.novajeepers.com
bigsteve3184 is offline   Reply With Quote
Old 02-25-2004, 04:39 AM   #4
mean green
thanks guy i appreciate the help i thought about selling it cus it is hard to drive but i'll try this first and see what happins ihope it works
Glock Forum
