help with tires and wheels - JeepForum.com
post #1 of 5 Old 11-24-2013, 10:26 PM Thread Starter
woods1994
ok i have a 2003 jeep grand cherokee 2wd stock everything. im looking at buying new tires (size p245/70r16) and while i was buying them i thought i would look into buying some wheels too. the only problem is i have no clue what size i need to buy. and when i buy them will the tire size change also (i dont plan on lifting it just making it look more to my liking) . thanks for any help.
woods1994 is offline
post #2 of 5 Old 11-25-2013, 09:18 AM
apaTJ
Your wheel bolt pattern is 5x5 and you have 16 inch rims (as designated by the r16 on the tire size). You will need that rim size in a 7 or 8 inch wide rim. You won't be able to fit much larger tires, so I would stick to that size. Also pay attention to the backspacing. Your stock wheels have 5-5.5 inches of bs. A lot of aftermarket jeep wheels have much less bs to fit wider tires , and this will space your tires out. If your going for that look then great, just something you should know.
apaTJ is offline
post #3 of 5 Old 11-25-2013, 10:18 AM
wilson1010
You have to pay attention to the offset or backspace if you are buying aftermarket wheels.
Read about it here:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #4 of 5 Old 11-25-2013, 01:34 PM
emilem
2011 JK Wrangler
i just bout a 11 jeep wrangler and i want to put a lift on it but i dont know a thing about tires or what sizes goes with how many inches in a lift. any suggestions?
emilem is offline
post #5 of 5 Old 11-25-2013, 04:24 PM
apaTJ
Search the JK forum. Tons of info
apaTJ is offline
