-   Tires & Wheels (http://www.jeepforum.com/forum/f15/)
-   -   help with tires and wheels (http://www.jeepforum.com/forum/f15/help-tires-wheels-1825690/)
woods1994 11-24-2013 11:26 PM
ok i have a 2003 jeep grand cherokee 2wd stock everything. im looking at buying new tires (size p245/70r16) and while i was buying them i thought i would look into buying some wheels too. the only problem is i have no clue what size i need to buy. and when i buy them will the tire size change also (i dont plan on lifting it just making it look more to my liking) . thanks for any help.
apaTJ 11-25-2013 10:18 AM
Your wheel bolt pattern is 5x5 and you have 16 inch rims (as designated by the r16 on the tire size). You will need that rim size in a 7 or 8 inch wide rim. You won't be able to fit much larger tires, so I would stick to that size. Also pay attention to the backspacing. Your stock wheels have 5-5.5 inches of bs. A lot of aftermarket jeep wheels have much less bs to fit wider tires , and this will space your tires out. If your going for that look then great, just something you should know.
wilson1010 11-25-2013 11:18 AM
You have to pay attention to the offset or backspace if you are buying aftermarket wheels.
Read about it here:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
emilem 11-25-2013 02:34 PM
i just bout a 11 jeep wrangler and i want to put a lift on it but i dont know a thing about tires or what sizes goes with how many inches in a lift. any suggestions?
apaTJ 11-25-2013 05:24 PM
Search the JK forum. Tons of info
The time now is 10:13 PM.
