Quantcast help fast 2" RE lift on my cherokee - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > help fast 2" RE lift on my cherokee
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 01-09-2004, 02:17 PM   #1
Lint
I am doing lift and cant seem to get the track bar to line back up. There are no brackets in my kit and I needed to know if I have to drill a new hole or anything else, Thanks
Matt
2000 XJ Classic 4.0 rustys 4.5in Locked Flowmaster Exhaust, K&N Filter System
33's and cut, Front tow hooks. (more mods to come$?)
"Maybe, just once, someone will call me 'sir', without adding, 'you're making a scene'"
Lint is offline   Reply With Quote
Old 01-09-2004, 02:41 PM   #2
DefaZ
Matt
I (and most others on here) had the same problem. My 3" required that i drill a new hole, about 3/4" to the right of the old one. as far as your 2", you could have somebody rock the front end back and fourth while you wiggle the bolt back in. Check to see if your axle is centered on your front end after getting it all back together, and if it isnt, you may want to get a relocation bracket or an adjustable trackbar if you are looking to go bigger anytime in the future...
DefaZ is offline   Reply With Quote
Old 01-09-2004, 02:46 PM   #3
NotMatt
I just had the exact same problem, with the exact same lift... about 2 days ago.
Here's what I did, it's kinda ghetto, but it did work and I didn't break anything or lose any fingers.
You'll have to take your airbox out. Take a short piece of chain and wrap it around the driver's side motor mount by the exhaust manifold. Hook a come-a-long to the chain, then hook the other end of the come-a-long to the swaybar end link mount on the passenger side of the axle. Tighten up the come-along slowly and have a friend slide the bolt in. You won't need much force at all, just a nudge is all it will take as you can see since the holes are only off by about an 1/4 inch or so.
BTW, we came up with this solution only after numerous failed attempts and rocking the truck back and forth, having two big guys pushing on the driver's side, two guys standing in the engine bay, etc. That stupid bolt just would not go in.
NotMatt is offline   Reply With Quote
Old 01-09-2004, 03:04 PM   #4
Jeepin_Al
DAJC.......Get stuck!!!!
I had this issue with my TJ, I used 2 guys, but one was about 400 lbs so leaning on the jeep produced a pretty noticable effect, the come along idea sounds good, but why not just hook to the bumper or frame somewhere that you dn't have to worry about body damage, the idea is just to line back up the body with where it should be, GL, AL
"rejected by the signature police"
Jeepin_Al is offline   Reply With Quote
Old 01-09-2004, 03:26 PM   #5
Lint
Thanks for the fast help! I got it in rocking the truck back and forth with out to much prob. The back end needs to settle some and it seems like more than 2" but thats just fine with me, thanks again for all th help.
Matt
Old 01-09-2004, 04:26 PM   #6
XJCHIEF
i have had that kit for a couple of months and the rear didnt settle enough
'89 Cherokee Laredo
rebuilt engine, header, delta 40, intake with KandN, 3 core radiator. Fresh paint , BPI bumpers ,Warn 8000, Yakima Rack, Grant steering wheel, RE 4.5", t case drop, JKS discos, adj UCA, doestech shocks, 32"BFG M/T, Rockcrawlers, Pro comp Lights, Amp and 12" alumapro sub, RE Hack and tap.
'89 YJ
Chevy 350 engine and trans, fenderwell headers, dual flowmasters, Edelbrock intake and carb, KandN
Pro Comp 4" lift
33" mud terrains
XJCHIEF is offline   Reply With Quote
Old 01-09-2004, 06:43 PM   #7
NotMatt
I guess I could've just as easily hooked it on somewhere else, but the driver's side motor mount was a straight shot right down to the axle and it worked great. In either case, whatever works to get the bolt in
Mine seems kinda high in the rear as well, but from what I've been told, it will eventually even out, and after that it may start sagging even, because the add-a-leaf puts more stress on the leafs.
We'll see, I guess.
Glock Forum
